Author Topic: How To Safely Remove Paint Over Anodizing ?  (Read 4800 times)
427HISS
« on: March 25, 2018, 05:55:59 PM »
I purchased a stack injection from s FE'er, which he painted the throttle bodies. I planed on painting them my cars body color which is blue.
As I was taking apart the T/B, I noticed under the paint was blue anodizing !
So, how can I remove the paint without damaging the anodizing ?
« Last Edit: March 25, 2018, 05:57:36 PM by 427HISS »
Katz427
Re: How To Safely Remove Paint Over Anodizing ?
« Reply #1 on: March 26, 2018, 01:21:01 PM »
Anodising is just soooo thin, best too use a heat gun. Then maybe some lacquer thinner, almost everything aggressive enough too soften the paint will attack the anodising to some degree.
427HISS
« Reply #2 on: March 26, 2018, 01:57:22 PM »
I assumed so. I can't think of a mild produce that could be used safley ?
I wonder about some of the non-solvent cleaners ?
« Reply #3 on: March 26, 2018, 03:20:59 PM »
Brake fluid is pretty mild dont know how
it is on anodizing but i think it can take
brakefluid. it solve the paint in a couple of days
wowens
« Reply #4 on: March 26, 2018, 03:56:38 PM »
Try some citrus based paint remover on a scrap anodized part. If it doesn't hurt it, then try it on the paint. Guessing .
Woody
427HISS
« Reply #5 on: March 26, 2018, 07:36:23 PM »
Few good ideas.
Cyclone Joe
  • Joe
« Reply #6 on: March 26, 2018, 10:26:39 PM »
You can always have it re-done if it gets messed up.  I know on gold anodize acetone and IPA applied to a rag and then wiped on it didn't seem to affect it.
Joe
gt350hr
« Reply #7 on: March 27, 2018, 11:09:05 AM »
 Anodizing is an electro chemical coating process. Only a caustic chemical like oven cleaner or something with acid will bother it . Brake cleaner , carb cleaner , non caustic paint removers etc will remove the paint and as long as you don't "rub" on the anodizing , it will not be affected. Since the anodizing process etches the aluminum it is often used to help paint adhere to aluminum parts besides inhibit corrosion ( it's main purpose).
427HISS
« Reply #8 on: March 29, 2018, 02:35:00 PM »
Great information.  I'll look into it.
