FE Technical Forum
Max static & dynamic compression ratio
Topic: Max static & dynamic compression ratio (Read 5665 times)
DEANs427
Full Member
July 22, 2012, 05:01:44 PM »
what is recognized maximum comp ratios on race gas and a non O-ringed block? is 14:1/ 11.8: too high?
using a pond block
1956 Ford Gasser 427FE
1966 Fairlane
1966 Bronco supercharged
Administrator
Re: Max static & dynamic compression ratio
Reply #1 on:
July 22, 2012, 07:37:42 PM »
I don't think that's too high, Dean. I would say with Cometic head gaskets you could go to 15:1 - Jay
DEANs427
Full Member
Reply #2 on:
July 23, 2012, 10:50:33 AM »
my initial target numbers were a full point lower but measurement after assembly shows I am higher than I feel comfortable with. I know what detonation can do !
1966 Fairlane
cwhitney
Newbie
Reply #3 on:
July 23, 2012, 07:45:26 PM »
I have a cast Iron Pond block with Cometic head gaskets with 14+ compression ratio with no issues.
cwhitney167@gmail.com
FE Technical Forum
