Author Topic: Confused On Holley 600cfm Carb ?  (Read 5302 times)
427HISS
« on: March 18, 2018, 08:15:31 PM »
I have a Holley that I believe is a 4150 ?
It does not have the brass tag.
The two numbers I read are below, but do not have the numbers before and after these numbers like shows on the link I provided.
I want info on exactly what carb this is, and to buy a rebuild kit. Some of the numbers on the site say it's for the Shelby GT 350.
3259
List- 4366
Link-
http://www.carburetion.com/CarbNumber.asp?Number=R3259-1%20S2MS-A
Re: Confused On Holley 600cfm Carb ?
« Reply #1 on: March 18, 2018, 08:39:18 PM »
Nope.... not for a GT350.
It's a 4160, 570cfm carburetor originally made for a 440 Dodge with an automatic transmission, built on November 21, 1969.
« Last Edit: March 18, 2018, 08:41:26 PM by Drew Pojedinec »
« Reply #2 on: March 18, 2018, 08:44:19 PM »
Ohh and when buying a kit, I think that carb has an accelerator pump transfer tube, so you'll need the orings for that.
427HISS
« Reply #3 on: March 18, 2018, 09:11:47 PM »
orings for that.?
« Reply #4 on: March 18, 2018, 09:58:21 PM »
Some carbs have a transfer tube between the metering block and main body for the accelerator pump.
These carbs have two orings for the tube and a different metering block gasket.
427Fastback
« Reply #5 on: March 18, 2018, 11:44:33 PM »
A 3259 is a Shelby carb but that's not your carb #.The list # is and yes its a 440 Dodge carb..
1936 Diamond T 212BD
1990 Grizzly pick-up
427HISS
« Reply #6 on: March 19, 2018, 04:49:36 AM »
Will any 4160 570cfm carb rebuild kit work or do I need more numbers ?
Is it 1969 (+/-) era carb ?
Just looked it up. This is my exact carb ?
http://www.carburetion.com/CarbNumber.asp?Number=R4366
Rebuild kit-
http://www.carburetion.com/products/productdetails.aspx?part=KT-5165A
Thank you guys for your expertise.   8)
« Last Edit: March 19, 2018, 05:22:56 AM by 427HISS »
« Reply #7 on: March 19, 2018, 12:51:55 PM »
If it was me?  I'd use
3-2001-QFT
https://www.summitracing.com/parts/qft-3-2001qft/overview/
But I'd make sure it has the accelerator pump transfer tube first.... just pop off the metering block
427HISS
« Reply #8 on: March 19, 2018, 05:13:39 PM »
Hey Drew,
Is the link you provided have that provision or do I need some other part number ?
« Reply #9 on: March 19, 2018, 06:00:08 PM »
It has everything you need, assuming you have the transfer tube I mentioned (you need to take the metering block off to know, I simply don't recall, nor is it in my notes).
Only thing it does not contain are floats and VS diaphragm as I buy these elsewhere, tho in your case I think I'd look at the existing parts before replacement.... in my case the carbs are for sale, so it's just a good practice to change them.
