Author Topic: SOHC cams - a couple pair that are "extra"...  (Read 5175 times)
« on: July 21, 2012, 06:14:28 AM »
 have a couple pair of SOHC cams in inventory here that need a new home. Projects that changed direction.
They are brand new, and have never been run. One pair have been installed & removed.
Both pair are custom ground billet cores from Comp - new items - not old stock that's been sitting around.
Both are street oriented but high perf stuff.
Normal pricing on these is $800 pair plus UPS
These are $700 pair including shipping to the lower 48
First pair is
GRIND #: 427FE 8566/ 8566 R112
GROSS VALVE LIFT .598 .598
VALVE TIMING OPEN CLOSE
@ .050 INT 26 66
EXH 70 22
SPECS FOR CAM INST. @ 110.0 CENTERLINE
INT EXH
DURATION @ .050 272.00 272.00
LOBE SEPARATION 112.0
Second pair is
GRIND #: 427FE 8566/ 8566 R112 +4
GROSS VALVE LIFT .591 .591
@ .050 INT 22 58
EXH 66 14
SPECS FOR CAM INST. @ 108.0 CENTERLINE
INT EXH
DURATION @ .050 260.00 260.00
FE Flat tappet - - should be an interesting custom solid flat...$125
GRIND #: 427FE 7406/ 6281 R112
GROSS VALVE LIFT .641 .637
@ .050 INT 22 42
EXH 56 12
SPECS FOR CAM INST. @ 100.0 CENTERLINE
INT EXH
DURATION @ .050 244.00 248.00
LOBE SEPARATION 106.0
