Author Topic: Spragless torque converter  (Read 5611 times)
billtroth
« on: March 10, 2018, 08:04:21 PM »
I ordered a new converter to match to my new Joel's on Joy C4.  I opted for a spragless design based mainly on more durability and car is  only driven on the track.  I would be interested in any thoughts and experience on sprag versus spragless converters.
Bill Troth
Aftershock427
1964 Galaxie NNS
Re: Spragless torque converter
« Reply #1 on: March 10, 2018, 08:37:59 PM »
Bill -
A spragless converter will cost you a bit of mph in the traps.  Are you worried about breaking stuff?  The new sprags are pretty good, though for peace of mind you can specify the Sonnax "Mechanical Diode" type.  Those give you the speed advantages of a sprag converter with nearly the indestructability of a spragless setup.
JMO, of course!
- Bill
billtroth
« Reply #2 on: March 11, 2018, 03:11:41 AM »
Thanks for the information.  The sprag on the converter I am replacing was trashed so I am a little leary of that happening again.  Also, I race Nostalgia Super Stock which is all index racing where consistency is more important than low e.t..  I have heard that a spragless, all things being equal, will run more consistently but I'm not sure that would true or just perception.
Bill Troth
Aftershock427
1964 Galaxie NNS
« Reply #3 on: March 11, 2018, 09:04:02 AM »
I've been told the same thing about spragless converters, they will cost you some ET but run more consistently than a converter with a sprag.  If consistency is your goal, you probably made the right choice.
manofmerc
« Reply #4 on: March 13, 2018, 04:46:45 AM »
One  of my fellow bracket racers bought a new convertor with this mechanical diode sprag .What is the difference between this and a standard sprag ? Just curious
FirstEliminator
« Reply #5 on: March 13, 2018, 07:33:16 AM »
Mechanical Diode is like a ratchet. Whereas a roller or element type sprag is like a wedge that holds a door open.
    As a transmission rebuilder I can say I've never heard of a Spragless convertor, other than a fluid coupling. But, I'm not much into racing stuff.  I'd like to see the inside of a spragless.
« Last Edit: March 13, 2018, 07:36:24 AM by FirstEliminator »
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
57 lima bean
« Reply #6 on: March 13, 2018, 01:56:50 PM »
Very disappointed with the performance when I ran one. :(
billtroth
« Reply #7 on: March 14, 2018, 08:39:32 PM »
Ina spragless converter the roller sprag assembly is replaced with a solid billet .  Here's a link that explains better than I can.
https://autotransdesign.freshdesk.com/support/solutions/articles/9000098628-sprag-diode-roller-clutch-spragless-101-high-performance-torque-converter-
Bill Troth
Aftershock427
1964 Galaxie NNS
