Author Topic: Tunnelwedge preference  (Read 12030 times)
wowens
« on: March 05, 2018, 11:19:35 AM »
If you were building a all most unstreetable 482 street engine, manual trans, 3200lbs, would you use a BBM or unmolested Ford manifold ?
Woody
Dumpling
Re: Tunnelwedge preference
« Reply #1 on: March 05, 2018, 02:16:06 PM »
A decent Dove should feed the beast.
« Reply #2 on: March 05, 2018, 03:18:40 PM »
A stock, unmolested Ford intake will flow ~375-390 cfm in each runner, the BBM quite a bit more than 400 cfm as cast.  The ones I have flowed hit 485-505cfm with just a simple gasket match to the BBM heads.  Joe-JDC
« Reply #3 on: March 05, 2018, 06:17:12 PM »
Not trying to get the original question off track, but Joe, which would work better on a milder street engine? Would the OE Ford intake have better port velocity than the BBM, given such a difference in the CFM?
For a max effort, the BBM seems the obvious choice.
« Reply #4 on: March 05, 2018, 06:26:58 PM »
That Ford tunnel wedge flows 410 cfm in every port.  I raced it for years on a 452 MR.  You can see just how much smaller it to the gasket than the BBM.   I try not to say anything negative about BBM, because it is a very nice piece, and on my flow bench it flowed 445 up to 475 cfm as cast, and a simple gasket match to those Edelbrock 7224 gaskets netted 490+ cfm.  I personally think the stock Ford would be excellent for smaller street engine.  A friend who also races a 390/427,  gasket matched his Ford TW to his Edelbrock heads, and lost 20 lbft everywhere, and went slower.  Joe-JDC
« Reply #5 on: March 05, 2018, 06:41:50 PM »
Thanks for the input, Joe. I'm certainly not trying to say anything negative about the BBM, because it seems to be a super nice piece, but seems more oriented towards top end performance builds, which is exactly what the tunnelwedge is made for. In those cases, the BBM seems to be the no-brainer. Still, some guys like to use them on the street on milder builds, just for the looks. In that case, the OE Ford would seem the better choice.
scott foxwell
« Reply #6 on: March 05, 2018, 06:42:02 PM »
The cross sectional area of the runner entry in the plenum will tell you more about which intake will work better on which engine.
« Reply #7 on: March 05, 2018, 07:26:49 PM »
I think even on an all-out engine the BBM runners are too big.  The one I looked at at Tim Meyer's shop was huge.  If I was going to go with a tunnel wedge I think I'd try to find a stock one or a Dove.  JMO, of course...
427HISS
« Reply #8 on: March 05, 2018, 08:56:21 PM »
If my first offered buyer of my Dove 2x4 Tunnel Wedge falls through, I now have mine ready to sell.
FElony
« Reply #9 on: March 05, 2018, 09:50:56 PM »
As I've mentioned a couple times in the past, I bought my BBM in Oct of '15 and have yet to open the box it came in because I was disappointed in the stratospheric cfm runner ratings. I have yet to see mention of the "other" application for this piece, aside from a big-inch max effort mill.
Edit: That would be Oct of '16, not '15. No ideas yet?
« Last Edit: March 06, 2018, 12:31:52 PM by FElony »
wowens
« Reply #10 on: March 06, 2018, 08:31:12 PM »
Thanks guys
Woody
andyf
« Reply #11 on: March 06, 2018, 08:43:11 PM »
Out of the box BBM tunnel wedge worked great on this 482 inch FE. 640 ft-lbs of torque at 5400 rpm:  http://www.hotrod.com/articles/dyno-tested-make-700-hp-trick-flows-new-fe-heads/
If you really want to get on it then shift at 6500 and drop back to the torque peak in the low 5000 range. Should make a 3200 lb car stand up and go.
CaptCobrajet
« Reply #12 on: March 06, 2018, 09:15:07 PM »
I think if you are willing to put enough solid roller camshaft in a 482 to take it to an rpm band that is friendly to a tunnel wedge "in general", the BBM will be just fine.  I had two  identical, fairly aggressive hydraulic roller 482s on the dyno back to back a while ago.......a tunnel wedge got better than a BT dual plane 2x4 at 5300 rpm.  Below that, the dual plane ruled.  If you have a 7000 to 7500 rpm engine under it, a tunnel wedge of any mfg. will be better upstairs.  It will not be better from idle to 5000-ish rpm.  If you have a 6000-6200 rpm redline, you should think it over carefully.  Street driveability, idle to 4500, would be better with a MR dual plane.  With that said, a healthy 482 will still shred the tires with either style manifold........
Blair Patrick
FElony
« Reply #13 on: March 06, 2018, 09:35:02 PM »
Turbo?
andyf
« Reply #14 on: March 07, 2018, 12:13:43 AM »
The 482 with the BBM tunnel wedge that I worked on recently was making more than 550 ft-lbs at 4000 rpm so I think that is adequate for a street car. No doubt a dual plane intake would have more torque downstairs, but 550 at 4000 is pretty decent. The engine isn't in the car yet so I can't say exactly how it runs yet, but I think it is going to be fine. The cam can always go one size smaller if we need a little more torque down low, or we can add some gear in the rear. This engine had dual throttle body fuel injection which probably helped. It can be tough to get dual carbs dialed in on a big single plane intake. With dual throttle bodies and a computer controlled ignition it is easier to dial in a tune.
