Author Topic: Damn! Water in oil  (Read 10089 times)
Re: Damn! Water in oil
« Reply #15 on: March 06, 2018, 09:40:05 PM »
Check back with us on gasket make/type. Also, check the gaskets around the water passages with a mike for similar thickness around the gasket perimeter. Object? To see if mis-matched intake/head planes eventually caused the leak.
66FAIRLANE
  • Andy
« Reply #16 on: March 06, 2018, 11:35:31 PM »
Gaskets were whatever came in the Felpro full kit. As stated it was most likely very low on coolant. Had I kept up with the water pump leak it probably would not have happened.
