Author Topic: Need help ID this roller tip rocker arm  (Read 6646 times)
paroerno428
« on: February 13, 2018, 10:44:24 AM »
I acquired a set of 16 red anodized roller tip rocker arms in the mid 1980's, have no idea who manufactured them. Pretty sure they are not DOVE or Harland Sharp. They have a Ford style tight fitting adjuster screw (no lock nut), no bushings in shaft hole, and a groove cut in center for oil supply. Attached are 2 pics. Any idea who made these?
Re: Need help ID this roller tip rocker arm
« Reply #1 on: February 13, 2018, 11:38:26 AM »
Personally haven’t seen them before but the bottom left is that a piece of dirt or a crack near the adjuster, probably dirt but just thinking out loud.
« Reply #2 on: February 13, 2018, 12:46:09 PM »
Maybe Crane Cams?
« Reply #3 on: February 13, 2018, 12:54:11 PM »
I'm leery of any interference fit with steel/aluminum. Wear will cause a need for a locknut in a fairly short time.
JamesonRacing
« Reply #4 on: February 13, 2018, 02:14:24 PM »
Dove made a lot of rocker arms, many anodized a different color and sold under the Brand name.  I suspect those in the pic originated from Dove, maybe sold as Comp Cams back in the day.
wowens
« Reply #5 on: February 13, 2018, 02:35:30 PM »
Not bushed and no jam nut, don't know maker but they look inferior to me.
Woody
Faron
« Reply #6 on: February 13, 2018, 05:45:47 PM »
Me thinks perhaps they are not supposed to have that interference adjuster in there , as there would be no need for all that clearance around the hex at the top ,IMHO
« Reply #7 on: February 13, 2018, 11:17:09 PM »
Definitely not Harland Sharps. I think Jameson called it. Dove did make rockers in red and resemble their body shape. Dove never used a bushing as far as I'm aware, either. I think someone put those factory adjusters in there and looks to be a no-no. JMO
« Reply #8 on: February 13, 2018, 11:39:03 PM »
Looks pretty similar to this newer Dove:
paroerno428
« Reply #9 on: February 14, 2018, 07:41:22 AM »
Consensus is rocker arms look like DOVE design (but not anodized Blue), someone wrongly added Ford style screw (must replace with DOVE screw/jamnut). The Ford style adjuster installed in red aftermarket rocker really threw me off, but the mismatched parts theory makes sense. DOVE is no longer in business, but I'll try to obtain correct fitting screw/jamnut elsewhere, thanks everyone for the help
« Reply #10 on: February 14, 2018, 10:58:54 AM »
Smith Brothers has probably got the adjusters you need...
« Reply #11 on: February 14, 2018, 11:59:06 AM »
Dove did them for a lot of other folks over the decades.  They did Speed Pro in black, possibly Edelbrock in red....
« Reply #12 on: February 14, 2018, 01:14:16 PM »
For a long time, Dove made more rocker arms than anybody else.
