Author Topic: Solid motor mounts for '64 Galaxie NSS car  (Read 11261 times)
billtroth
« on: February 04, 2018, 04:32:26 PM »
I have the motor out of my ’64 Galaxie NSS car and I am considering using solid motor mounts when I re-install it. I have been running the chain to block trick but looks odd and, I need space for plumbing in Accusump tank. I am a little leery of fabricating a block plate with my limited welding skills. I have seen a post here on pinning the stock motor mounts with 3/8” bolts but, unless I am missing something that will only effect the passenger side.  Also, I run a marine block and there are 4 holes machined for four-hole mount which I would like to use in lieu of the 2 bolt stock mounts.  Has anyone fabricated and run solid motor mounts in their Galaxie with good results?  Any advice would be appreciated.  Thanks in advance for input.
Bill Troth
Aftershock427
1964 Galaxie NNS
gdaddy01
Re: Solid motor mounts for '64 Galaxie NSS car
« Reply #1 on: February 04, 2018, 04:48:24 PM »
it would effect the driver's side , I run the bolts through the rubber mounts and works ok for me . I think if you run solid mounts on a street car you will have more vibration than you want to put up with . jmo
wowens
« Reply #2 on: February 04, 2018, 05:04:10 PM »
I have run a front motor plate with a urethane trans mount, vibration was not a issue. Mostly street with a few mid 10 passes.
Woody
« Reply #3 on: February 04, 2018, 05:32:02 PM »
Solid (steel, not bolts in OEM rubber mounts) mounts are fine.
Just don't also run a solid trans mount as you WILL break a tranny case! Ask me how I know this!
« Reply #4 on: February 04, 2018, 06:34:22 PM »
I agree with gdaddy. You only need to pin the driver mount, as it is the one trying to separate. Not a fan of solid mounts unless it is a block plate. Too much stress on the side of the block. Not sure if there are any aftermarket poly mounts for your Galaxie. I found a nice set for my car, that doesn't require a torque strap.
Edit: Maybe give this place a try if you don't want to pin your mounts. It says they have custom mounts for an FE.
http://www.tinmanfabrication.com
« Last Edit: February 04, 2018, 06:47:50 PM by Nightmist66 »
billtroth
« Reply #5 on: February 04, 2018, 07:30:35 PM »
Thanks for the information.  The car is a strip only Nostalgia Super Stock with no street use.  Jay's '64 Galaxie SOHC is one of the highest H.P. Galaxies there is.  Jay ( or anyone else knows ) what mounts does it have?
Bill Troth
Aftershock427
1964 Galaxie NNS
« Reply #6 on: February 04, 2018, 10:53:59 PM »
I use stock mounts with the bolt through them as described earlier in the thread.  Never had a problem.
billtroth
« Reply #7 on: February 05, 2018, 01:24:43 PM »
Jay, thank you very much for the information.  If that worked for you on your 9 second car it sure will work in my ( hopefully, its low 11's best now) high 10 second Galaxie. I'll drill and bolt.
Bill
Bill Troth
Aftershock427
1964 Galaxie NNS
Jim Comet
« Reply #8 on: February 05, 2018, 03:23:08 PM »
Do you also run a limiting strap when using the bolt through the motor mount on the higher horsepower cars?
« Reply #9 on: February 05, 2018, 04:26:06 PM »
I use a 3/8 turnbuckle from the frame to the head.  Also have done the 3/8 bolt in a motor mount trick - never had an issue with that.
« Reply #10 on: February 05, 2018, 05:31:11 PM »
I never used a limiting strap on my Galaxie, just the bolted together mount.
Jim Comet
« Reply #11 on: February 05, 2018, 06:31:53 PM »
So you don't think with an oem block at the 600hp level that the twisting forces on the block where the mount attaches could possibly stress or distort the block?
« Reply #12 on: February 05, 2018, 06:47:38 PM »
My opinion is that's not a concern.
John67427
« Reply #13 on: February 06, 2018, 11:07:54 AM »
Years ago, in the early 1970’s after breaking a few and not thinking about running a bolt thru , my brother made a solid set. He took measurements and removed the rubber. He then took strap steel and welded it to the outside perimeter. I’ve used them to this day. Not something I would do on a street vehicle as you really feel engine vibration in the car. Solid engine mount be sure to use urethane trans mount...
 Used these on 4 different FE motors from 12,11,10 and 9 seconds and it doesn’t affect the mount area
« Last Edit: February 07, 2018, 04:02:23 PM by John67427 »
« Reply #14 on: February 06, 2018, 01:10:55 PM »
Many years back I made my own solid mounts using angle iron.  Worked fine and used them in my black car for years.  I finally wanted to get rid of the shaky vibration and put stock mounts back in it with a turnbuckle on the drivers side.
