Author Topic: AN fittings...aluminum or steel?  (Read 9504 times)
Re: AN fittings...aluminum or steel?
« Reply #15 on: February 02, 2018, 09:50:35 AM »
A friend of mine turned me on to the Aeroquip socketless hose & fittings years ago, that's pretty much all I use now, along with hard line when I can.
There is a slick tool available for assembling the socketless hose, a bit spendy but worth it if you are going to do a bunch. You can buy it direct from the company or from Summit. Here's a link:
https://koultools.com/product/push-lock-hose-tool/
« Reply #16 on: February 03, 2018, 10:37:07 AM »
Typically it helps to heat the hose end up a little bit, but it's a fine line between just enough and too much heat.
Yes, I also heat the end with a small propane torch with a soft flame and use lots of WD-40. I tried all kinds of oils and found the WD-40 worked the best for me.
