Author Topic: '62 406 tri-power for sale  (Read 16615 times)
Weston
« on: July 06, 2012, 07:21:18 PM »
I have decided to sell my 406 tri-power. I have to many projects that are not getting done.    The engine is apart and needs some work before it can be put back together.  Block #C2AE-J std.bore. Heads #C2SE-B no cracks but need some work. Rods #C2AE-B 13/32 bolts, have been resized. It has a 390 crank, all balanced. Carbs need kits also. I have new rod & main bgs. and piston rings too.   $2500.00 My shop # 605-835-9429 So.Central So.Dak. Call for more info.       Also I have a pair of C3AE-C heads (bare) no cracks-need some work,  $100.00 ea.       Wes
428kidd
Re: '62 406 tri-power for sale
« Reply #1 on: July 08, 2012, 10:29:21 PM »
Weston can i get some pictures of the engien please. Thanks Lance.
Weston
« Reply #2 on: July 09, 2012, 08:56:59 PM »
   pictures of motor, sorry i'm not to good with pictures had to have some one else help me.   Still not to good .
« Last Edit: July 10, 2012, 12:47:45 PM by Weston »
Weston
« Reply #3 on: July 09, 2012, 09:03:08 PM »
pic cont.
Weston
« Reply #4 on: July 09, 2012, 09:03:47 PM »
cont.
Weston
« Reply #5 on: July 09, 2012, 09:04:29 PM »
cont.
Weston
« Reply #6 on: July 09, 2012, 09:04:54 PM »
cont.
Weston
« Reply #7 on: July 09, 2012, 09:05:21 PM »
weld on intake
« Last Edit: July 09, 2012, 09:13:22 PM by Weston »
Weston
« Reply #8 on: July 09, 2012, 09:05:49 PM »
cont.
Weston
« Reply #9 on: July 09, 2012, 09:06:22 PM »
cont.
Weston
« Reply #10 on: July 09, 2012, 09:06:51 PM »
cont.
Weston
« Reply #11 on: July 09, 2012, 09:26:52 PM »
I will give you a few facts about the 406. First the intake has been welded on the right front.It looks like a good weld,the guy i bought it from was running  it so it should be ok. The best part about it is the standard bore. I was just going to hone, rering it and run it. Some one polished the sides of the rods and did some port work on the heads, just a basic cleanup & polish. The crank is a nice 390 unit that has been balanced to the pistons & rods. Also the block has been decked about .010 thou.     Thanks  Wes
« Last Edit: July 09, 2012, 09:29:14 PM by Weston »
overheated
« Reply #12 on: August 16, 2012, 05:55:41 PM »
Hi Wes:
interested in finding out more about the 406.has the block been line bored?any damage at all to the block?did you mention a cam? are those adj rockers...couldn't quite tell,are the carbs actual set of ford holleys?have the cam bearings been done in the block?...as you can see I have interest and probably be easier to talk in person....please email for cantact info
