Author Topic: FT timing set  (Read 4542 times)
FT timing set
« on: January 29, 2018, 01:46:25 AM »
Is there a good timing set for the FT ?
Jb427
Re: FT timing set
« Reply #1 on: January 29, 2018, 08:01:42 AM »
CaptCobrajet
Re: FT timing set
« Reply #2 on: January 29, 2018, 10:11:50 AM »
I think I have two or three new OEM double roller chains.  If you have good gears, the chain would work.  They are .220 diameter rollers.  Modern double row stuff is .250.  I have thought about just machining the bottom gear of a .250 set.  If you put one key in it, Jay's adjustable cam gear would fix it right up.
Blair Patrick
Re: FT timing set
« Reply #3 on: January 29, 2018, 10:57:16 AM »
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F272664740826
Ended up going with this, couldn't find any info on the chain, .220 v .250 . If it's a .250 then I could at least swap out the cast top gear with one of my old rollmasters . Being it's pretty much OEM it's most likely the .220 ya think ?
CaptCobrajet
Re: FT timing set
« Reply #4 on: January 29, 2018, 11:20:55 AM »
Hard to say.  If it was manufactured recently I'd bet it is .250.  Let me know what it is when you get it.  Would be good info.
Blair Patrick
TorinoBP88
Re: FT timing set
« Reply #5 on: February 01, 2018, 12:36:43 AM »
Does FT have a bigger hole in lower sprocket for bigger crank diameter?
I have a couple very good stock rollers too, but FE.  Probably 0.220.
Re: FT timing set
« Reply #6 on: February 01, 2018, 07:26:53 AM »
Yes,
Bigger ID on lower gear..
Re: FT timing set
« Reply #7 on: February 10, 2018, 12:33:42 PM »
the enginetech set looks to be ok at least. made in US/India so it say. The chain does have the smaller .220 rollers though but i think its gonna work just fine for my needs.
