Author Topic: FINALLY! I'm getting to do some FE work.  (Read 6709 times)
AlanCasida
« on: January 20, 2018, 04:58:46 PM »
After several years of Mustang body/suspension work and side tracked on 521 Galaxie I am finally getting back to work on my 427/452.
Today I chopped up a perfectly good Trickflow 351C Track Heat intake to fit on my FE Power LLC intake adapter.  It sure is nice to get back to doing some engine/fab work. :)
Re: FINALLY! I'm getting to do some FE work.
« Reply #1 on: January 20, 2018, 07:40:33 PM »
Love cutting up a perfectly good manifold eh?
« Reply #2 on: January 20, 2018, 08:57:52 PM »
Looks good Alan, I'll be very interested to see how that intake performs...
AlanCasida
« Reply #3 on: January 20, 2018, 09:08:31 PM »
Sometimes you gotta do what you gotta do.  :)
« Reply #4 on: January 25, 2018, 11:36:37 AM »
At first I was going to say "why not just cut the entire bottom out?", but then I thought that it looked like a decent heat shield to keep radiant heat off the bottom of the intake. Is this for the Mustang, Alan?
AlanCasida
« Reply #5 on: January 25, 2018, 06:03:32 PM »
Yes this is for the Mustang. I had considered completely removing the bottom section but I was concerned the casting might be under some stress and it might "pop" and not be square anymore.
« Reply #6 on: January 25, 2018, 06:40:23 PM »
Alan I asked Jay about that as I've cut up two manifolds now.
He told me there should be no problem with that.
I have not seen any problems with mine. We ran one in Jays comparo II with no probs and the tunnel ram also seems to line up just fine.
« Last Edit: January 25, 2018, 06:42:27 PM by turbohunter »
AlanCasida
« Reply #7 on: January 25, 2018, 07:21:03 PM »
When I cut mine I used a rather crude method. I drill a series of 5/16 holes along the contour I wanted and then used a combination of a jig saw and cutoff wheel to cut between the holes. When I cut the last piece that connected the two sides of the front of the intake it "popped" and separated a little. Not a lot, maybe 0.010-0.020" but enough to convince me I made the right decision on my particular intake.
« Reply #8 on: January 25, 2018, 08:04:55 PM »
Good deal.
« Reply #9 on: January 25, 2018, 08:21:35 PM »
Ran both my tunnel ram and funnel web across the table saw. Took no more than a couple minutes.  No issues with either.
