Author Topic: BBM cam bearings  (Read 4042 times)
GJCAT427
BBM cam bearings
« on: January 20, 2018, 02:09:14 PM »
With the new iron BBM block on order, what cam bearing are needed? I`m trying to get all my ducks in order so when I get it I can assemble it.
Re: BBM cam bearings
« Reply #1 on: January 20, 2018, 02:22:28 PM »
I copy and pasted this off a former thread for myself. I think it was Mr. Lykins. Not sure though.
BBM block
Cam bearings are a special Durabond set.
Check distributor clearance
Check distributor oil feed from #1 cam bearing.
With a penlight check that all the oil feeds are lined up.
Use a lifter slid into the bores to make sure no cam bearings make contact. #2? Bearing may be close.
« Reply #2 on: January 20, 2018, 02:41:47 PM »
Use a Durabond FP-01 bearing set.
You can either use the front cam bearing in that set, or a front cam bearing from a standard FE set.  If you use the FP-01 front cam bearing, it will have to be clearanced for the distributor gear.
That FP-01 uses wide bearings and you have to be very careful about how far you drive them in.  The bearings are wide enough that they can block a lifter.
GJCAT427
« Reply #3 on: January 20, 2018, 03:43:18 PM »
Thanks Brent, Did you get my info ok? If you need more piston info I can send a copy of the sheet I got with the pistons. Garry
« Reply #4 on: January 20, 2018, 03:54:32 PM »
Yes, I got your info.
Pistons are made for the bore size, so all I need to know is the desired finished bore size.  The clearance is built into the pistons.
