Author Topic: Header question  (Read 5671 times)
Pat86004
Header question
« on: January 13, 2018, 10:14:08 PM »
I have run across a set of headers for a 68 ranchero, which i believe was a fairlane body with a 390, I am wondering if they will fit in a 68 cougar, or if they can be made to for without too much issue.
« Last Edit: January 13, 2018, 10:16:56 PM by Pat86004 »
Re: Header question
« Reply #1 on: January 13, 2018, 10:17:22 PM »
The Fairlane and Cougar engine compartments are significantly different, I doubt that they would fit without a lot of rework...
Pat86004
Re: Header question
« Reply #2 on: January 13, 2018, 10:25:30 PM »
Damn, was hoping. Could have been a significantly less expensive route.
482supersnake
Re: Header question
« Reply #3 on: January 13, 2018, 10:34:48 PM »
Do you know the brand of header? What are the specifics, tube diameter? Some were model specific others were interchangeable between fairlane and mustang platforms.
Pat86004
Re: Header question
« Reply #4 on: January 13, 2018, 10:50:17 PM »
I unfortunately have no clue.
Re: Header question
« Reply #5 on: January 13, 2018, 11:09:29 PM »
Like 482Supersnake said, some FE headers will fit both the Mustang/Cougar and Fairlane/Comet and some won't. Both are shock tower cars, but like Jay said the engine compartments aren't exactly the same. Also, years ago some of the FE headers would fit shock tower cars with an automatic transmission, but not cars with a manual transmission ( due to clutch linkage interference ). You may just have to try them and see if they fit. It's possible you may find they will work if you modify or relocate some tubes. Look on them close for anything that looks like a part number stamped on them.
Pat86004
Re: Header question
« Reply #6 on: January 14, 2018, 06:37:04 AM »
Thanks guys, I'll probably just let them slip away. It would be a 7 hour round trip of driving to get them.
Pat86004
Re: Header question
« Reply #7 on: January 14, 2018, 08:16:26 AM »
On that note, I'm open to suggestions for what headers will work for anything resembling a reasonable price.
Re: Header question
« Reply #8 on: January 14, 2018, 09:00:12 AM »
Which heads are on the Cougar?  Exhaust port location will be the first hurdle. If 390 and unibody heads, the choices are slim without header modification
Pat86004
Re: Header question
« Reply #9 on: January 14, 2018, 09:28:40 AM »
The heads are at the machine shop currently. I can not remember the casting number they are the gt heads though.
Pat86004
Re: Header question
« Reply #10 on: January 14, 2018, 09:33:49 AM »
I do have access to a set of c8ae-h heads. I could pick them up for reasonable price and have those worked instead. If I buy those heads, they come with the headers....so I guess I could see if I could make those headers work
« Last Edit: January 14, 2018, 09:35:42 AM by Pat86004 »
Re: Header question
« Reply #11 on: January 14, 2018, 09:46:07 AM »
So C8AE-H are arguably the lowest performing heads on an FE, although in mild applications they do fine.  Very few headers fit them and be prepared that the ones that come with them may not, even if someone used them.
The exhaust port in relation to the bolts is about 1/4 inch lower on C8AE-H heads, so there are gasket sealing issues with a mismatch if it's the more common CJ/early port header design.
Look close, and I would also expect Fairlane headers to NOT fit, although there were some listed in the past, most don't fit both
Pat86004
Re: Header question
« Reply #12 on: January 14, 2018, 09:14:42 PM »
Thanks for the advice guys, I passed on the deal, and am back in the market for headers, and an intake. The last 2 major things I need.
