FE Technical Forum
482 stroker carb size and fuel pump
Topic: 482 stroker carb size and fuel pump (Read 5715 times)
Jb427
Sr. Member
January 07, 2018, 11:38:30 AM »
What is a good size carbs for a 482ci engine and a good place to buy a custom pair for my build.
I would like to run a mechanical fuel pump as well.
I am running bbm cnc heads bbm 2x4 tunnel wedge intake 700 lift solid roller cam 10.5 compression ratio.
Re: 482 stroker carb size and fuel pump
Reply #1 on:
January 07, 2018, 11:59:19 AM »
We use a pair of custom made Quick Fuel 750s on the ones we build
Jb427
Sr. Member
Reply #2 on:
January 07, 2018, 12:05:04 PM »
What about a mechanical fuel pump for and engine combo like this?
Reply #3 on:
January 07, 2018, 12:08:52 PM »
I use custom Quick Fuel carbs as well, usually 725-750 cfm.
If you’re around 600 hp, a modified carter or an edelbrock pump will work. If you’re over that I would suggest an electric pump to keep up.
Instagram: brentlykinsmotorsports
YouTube: Lykins Motorsports
Reply #4 on:
January 07, 2018, 04:35:54 PM »
Clay Smith makes a high volume mechanical pump for the FE. The size of the pump body requires a little clearance work on the corner of the block above the oil filter adapter.
Link:
http://www.claysmithcams.com/clay-smith-fe-ford-mechanical-high-volume-fuel-pump/
FE Technical Forum
