Author Topic: FE Block Pressure Test Video?  (Read 11383 times)
ACHiPo
« on: January 04, 2018, 11:24:01 PM »
I've searched without luck on information for which passages are and are not tested as part of an FE pressure test.  Can someone point me to a video, cut-away drawing, etc. that makes it clear?
Thanks!
Re: FE Block Pressure Test Video?
« Reply #1 on: January 05, 2018, 06:14:57 AM »
As many as you can.
You can pressure test the water passages, which will find cracks in cylinders, porous lifter bores, etc.
You can also pressure test the oil passages, which will find a drill-through on an aftermarket block, crack in a main/cam passage, etc.
Most shops that are equipped to do it have the specialized plugs/manifolds to block whichever holes need to be checked.   They will put 30-40 lbs of air pressure through and watch for a leak-down over time.  If it leaks, then they will start spraying around with a soap/water solution looking for bubbles.
ACHiPo
« Reply #2 on: January 05, 2018, 07:52:29 AM »
Brent,
Thanks.  I’ve found a video of a Bristol 6 cylinder oil galley test, but nothing on an FE, which I’m guessing is trickier.
AC
« Reply #3 on: January 05, 2018, 08:02:08 AM »
Same principle, just more holes to plug.
On factory FE blocks, you watch close for the oil passages going from the cam to the mains and from the cam to the decks.  On aftermarket blocks, you check everything, including the side main galleys.
For water, anything is game on a factory block.  On aftermarket stuff, I've found most issues are in the lifter bores.
« Reply #4 on: January 05, 2018, 08:10:13 AM »
On my SOG block, Blair found two pin-holes in the lifter valley, along the inner cylinder wall area. Probably from vent areas on the casting process, but they were not visible to the naked eye. He showed me with air pressure and spraying the area with a soapy solution. I'm glad it was checked, because I probably wouldn't have done that and that would have been a quick disaster. Brent has it right...ALWAYS check.
ACHiPo
« Reply #5 on: January 05, 2018, 08:52:26 AM »
How did you fix it, or did Blair just junk the block and start over?
« Last Edit: January 05, 2018, 08:56:19 AM by ACHiPo »
ACHiPo
« Reply #6 on: January 05, 2018, 09:16:45 AM »
Brent,
It's pretty easy to understand how to leak check water passages of a bare block before assembly, as that system is supposed to be pressure tight.  The oil system, however, is supposed to "leak" internally to distribute lubrication.  I guess I don't even know how many oil openings there are in an FE, but there have to be about 20--2 for the oil pump, 2 for the oil filter, 5 for the main bearings, 5 for the cam, 8 for the top end (I probably missed a few--maybe 30)?
« Last Edit: January 05, 2018, 09:28:47 AM by ACHiPo »
chris401
Home Made Coolant Pressure Test
« Reply #7 on: January 05, 2018, 10:12:39 AM »
A while back I bought the rubber plugs for FE and MEL coolant passages. A gauge, regulator and ball valve on the water pump plate. I am lacking cutting holes in some 1/2" plate to simulate the heads. The rubber plugs will hold up to 22 psi where I pressure test in car cooling systems. Some engines have to be tested cold to hot to cold and sometimes drivin to find a leak. Most shop probably just use a warm block, hot water and do fine.
I have not put my home made block tester to use yet. If you rig up something similar you should have a way to shield your self and your shop in case a 35 psi plug popped out.
« Last Edit: January 05, 2018, 10:16:11 AM by chris401 »
« Reply #8 on: January 05, 2018, 01:41:00 PM »
I use my manual hydrostatic pump and soapy water to pressure test both coolant and  oil passages. Works great and there's no doubt when and where a leak may be.
« Reply #9 on: January 05, 2018, 01:55:27 PM »
Junk a brand new $3500 siamesed bore block?...lol  I don't think so! I haven't seen the repair, so I'm not sure. I think he may have drilled and tapped the area to seal them up. Either way, it got repaired, and I'm sure in a solid way.
ACHiPo
« Reply #10 on: January 05, 2018, 02:52:53 PM »
How do you seal all of the oil openings, especially the mains and cam?
« Reply #11 on: January 05, 2018, 05:04:16 PM »
Rubber plugs in the mains, held in place with aluminum pucks and the main caps. Have used old bearings as well.  Grippers in the cam bearing journal's, have also used old mis aligned bearings here as well.  Improvisation..
ACHiPo
« Reply #12 on: January 05, 2018, 10:00:54 PM »
Thanks!  That helps me visualize it (although I'd still love to see a picture or watch a video).  What are "grippers" in the cam journal?
« Reply #13 on: January 05, 2018, 10:50:46 PM »
Gripper plugs for testing.  I use a lot of my plumbing test equipment, like the test plugs and hydrostatic pump.  Not the same as but Similar to the gripper type freeze plugs used for emergency repairs.  Just pressure tested a 391 block a few weeks ago.
ACHiPo
« Reply #14 on: January 06, 2018, 01:39:53 AM »
