Author Topic: Potential new Tunnel Port intake  (Read 19893 times)
« on: January 02, 2018, 02:14:17 PM »
At the PRI show I met a guy who is manufacturing Pontiac Ram Air V parts.  As some of you may know, that engine is a close cousin to a 427 Tunnel Port, and in fact I was told at the show that after Ford cancelled the tunnel port program, a bunch of the engineers at Ford who worked on it went to Pontiac and were instrumental in developing the Ram Air V.  Anyway, the topic has come up in the past about whether one of these Ram Air V intakes could be made to work on a tunnel port engine, using my tunnel port intake adapter.  The guy at the show is based in Indianapolis and was kind enough to bring me one of his single 4 barrel intakes, and let me take it home to check this out.
Over the new year's weekend I finally got a chance to look at this.  I have one tunnel port intake adapter that is a defect and not usable, because a big end mill came loose during the milling operation and gouged one side of the intake adapter pretty good.  But the intake adapter's basic dimensions were intact, so it was a good candidate for checking to see if this intake would be made to work with the adapter.  One thing that was clear at the show was that the adapter's mounting surfaces would have to be machined down, a lot, to have a chance for success at this.  Also, it looked like the Ram Air V manifold's mating surfaces would have to be machined as well.
Measurements I took over the past couple days showed that I needed to machine the maximum amount off the surfaces of the intake adapter.  So, I took 0.800" off each manifold mounting surface of the adapter so I could see where we were after that.  Here's a picture of this defective adapter, with the manifold mounting surfaces machined:
Of course if I went forward with something like this it would not look so rough, but I needed to machine it this way to see what the problems might be.  I was able to confirm that there was enough material in the intake adapter to allow me to counterbore a hole for the bolts that go into the cylinder head, although special low-head capscrews would probably be required.  One area of concern is the gasket area above the ports; there is only about 0.175" there and I'd feel better if there was more like 0.250".  But at this point, it looked do-able.
Here are a couple pictures of the Ram Air V intake.  You can see how much like a tunnel port it is:
Finally, the picture below shows the intake sitting on the intake adapter:
As I had determined at the show, in this position the manifold does not fit far enough down on the intake adapter; the port openings are actually above the valve cover rail.  The flange of the intake is a little over 0.500" thick, and to make the roof of the ports line up between the intake adapter and the manifold, the flange of the manifold would have to be cut about another 0.325", leaving a flange thickness of only 3/16" or so.  But I think that would be OK; I've seen flanges thinner than that before.  The other issue is the port alignment, which is pretty close but would require either some porting on the intake manifold, or a new port program for the intake adapter to shrink the ports down so that they would match up with the Ram Air V manifold ports.
What do you guys think of this combination?  Would it be worth pursuing?  I don't know what the market is like for the single 4 tunnel port intake manifolds, but it seems like you could get one for less than you'd have into one of my adapters plus this Ram Air V intake with the requisite machining ($779 for the TP intake adapter and ~$700 for the manifold, plus $85 to machine the flanges so it would fit).  You'd also have to make custom intake gaskets, because there's no room for an O-ring seal between the ports of the intake adapter and the manifold.  But if you really wanted to do it, you could...
Any comments welcome - Jay
andyf
Re: Potential new Tunnel Port intake
« Reply #1 on: January 02, 2018, 02:33:59 PM »
That is a nice looking intake the guy is casting. If it was me I'd modify either the intake or the adapter for injectors and run EFI. That way I wouldn't need to worry about sorting out the wet flow in the intake. It might work just fine or it might not but EFI would get rid of that variable. I assume that is a 4500 bolt pattern on the intake? So a big 2000 cfm throttle body would fit on there. Would be a very cool looking setup.
« Reply #2 on: January 02, 2018, 03:02:21 PM »
That's actually a 4150 pattern on the carb flange, but there is enough meat to drill it either way.  I'm sure that that's an option with this intake...
« Reply #3 on: January 02, 2018, 04:33:19 PM »
I don't know how much of a market there is, but the timing of your post is good - Vintage Cylinder Heads just announced yesterday in the old FE Forum classifieds that they will have new Tunnel Port aluminum heads available in about 4 months. No word from them if they intend to market an intake manifold too, so demand for existing manifolds may increase. Details are a little slim yet on the new heads, looks like they will come with 2.09" & 1.66" valves, no word on if larger valves will be offered.
wcbrowning
« Reply #4 on: January 02, 2018, 04:39:11 PM »
How well do tunnel port heads flow?
Katz427
« Reply #5 on: January 02, 2018, 05:43:48 PM »
I will leave it to Blair Patrick as he has a good idea what happens with the pushrod tube and airflow. I think Jay's raised straight port with offset pushrod really is the best answer if you want a port with great flow.  It really is a tunnel port without the pushrod tube.
Dumpling
« Reply #6 on: January 02, 2018, 05:56:54 PM »
If someone was putting together a TP engine, I'd think at this late time, with all the other options out there that perform as well or better, that they'd be building it with originality and 'correctness' in mind.  Putting together a Pontiac/Ford hybrid doesn't seem like it would be their goal, unless that is something they dreamed of doing since back-in-the-day.  JMO
« Reply #7 on: January 02, 2018, 06:03:55 PM »
If someone was putting together a TP engine, I'd think at this late time, with all the other options out there that perform as well or better, that they'd be building it with originality and 'correctness' in mind.  Putting together a Pontiac/Ford hybrid doesn't seem like it would be their goal.  JMO
I agree with this. You don't see too many people running tunnelport stuff for pure performance, more for the cool factor. I could see myself grabbing a set of those heads the guy is advertising on the other forum, but I'd be bolting on one of the original intakes.
« Reply #8 on: January 02, 2018, 11:08:22 PM »
Jay, what I would like to see is a lightweight intake manifold with small round/oval runners that flows in the 400 cfm range, and a slightly larger version that is lightweight that flows in the 475 cfm range.  That would keep the velocity up, and make it possible for a smaller engine to make great hp/tq/ci, and the larger intake would work with larger stroker engines.   It doesn't take a large port to flow those numbers if it is concentric, and has a slight taper.  When I say lightweight, some time check out a Streetmaster's weight vs a Victor 427.  Joe-JDC
« Reply #9 on: January 03, 2018, 05:51:14 AM »
Now that is one very cool idea!  :)
But, on the other hand, demand is likely quite low...or maybe even extremely low. Something I'm sure you have thought of is running your 'ad' about this new idea and part in numerous Ford forums to get a handle on potential demand.
Although a seperate topic, JDC's idea has a lot of merit when it comes to weight. That spyder-looking and rather small exterior intake begs the question: can it be easily casted in some thermoplastic material ala' the OEM car manufacturers? Just a thought...
« Reply #10 on: January 03, 2018, 09:22:58 AM »
In the past it seemed like intakes were everywhere and good cylinder was hard to find , no thumb print , wacked out port jobs and cracks were the common place , if heads become available then the Intakes will be needed eventually and this could be a real good alternative if that happens or just have some intake manifolds cast specifically for the Tunnel port , it would be neat if someone can snatch up Dove Molds and put to good use
JamesonRacing
« Reply #11 on: January 03, 2018, 02:57:46 PM »
The 2-4V tunnel-port intake is already such a cool piece, would seem to be counter-productive to regress to a hybrid single 4V setup.  Factory single-plane tunnelport intakes seem to be available if a person really wants one, at a decent price.  I ran a factory dominator 1-4V on my FE back in the day, and did well.  Now that really good heads are available for FEs, I can't imagine ever using tunnelport stuff for racing.
So, my opinion is that there's not a market out there worth pursuing for that combo.
« Reply #12 on: January 03, 2018, 03:40:59 PM »
I'm kind of in agreement with most of the folks on this thread that this intake may be a solution looking for a problem.  Nevertheless, I know now what needs to be done to make one work, so if anyone runs across this thread in the future and wants one of these setups, let me know - Jay
andyf
« Reply #13 on: January 03, 2018, 04:46:33 PM »
Just because you can build it doesn't mean you should, or that anyone will buy it!
I get taught that lesson all the time in my business. I build a lot of custom parts for my own projects but when I add them to my website they don't always sell. Some do, some don't. Stuff I think is super cool is often too expensive for the average guy so sales are low. On the flip side, stuff I think is "run of the mill" is often priced low enough that it generates a lot of sales revenue. You just can't get too far ahead of the market..........
« Reply #14 on: January 04, 2018, 08:49:06 PM »
I agree with the extremely limited market on this. Heads and intakes seem to be everywhere now, and good ones at that. What the FE community really needs is a good, readily AVAILABLE block. 390 strokers can only take so much and the BBM seems to be on a very limited basis. The Pond isn't really any better than the factory blocks and the Shelby is WAY out of most peoples price range.
