FE Technical Forum
Oil Pan Question ...... Just To Make Sure
Topic: Oil Pan Question ...... Just To Make Sure (Read 3762 times)
December 05, 2017, 02:45:55 PM »
Pulling the 390 out of the '67 Mustang and I was hoping to use the same oil pan when I put it into this '63 Galaxie. Mustang has a Canton T-Pan on it right now. Will it drop into the Galaxie with no issue or am I going to need a different pan?
Re: Oil Pan Question ...... Just To Make Sure
Reply #1 on:
December 05, 2017, 04:09:37 PM »
I run a Cobra T pan on my 2 dr '64 Galaxie. Not sure how comparable the Canton version is?
Reply #2 on:
December 05, 2017, 06:24:09 PM »
Should be real close to the same I'd imagine! I'll give it a try.
hvywrench
Jr. Member
Reply #3 on:
December 05, 2017, 07:27:18 PM »
I run a Canton T pan in my 64 as well.
I have "heard" that one of the concerns is clearance with the larger front sway bar.
I have the smaller bar and no problems with clearance anywhere.
Bill
FE Technical Forum
