Author Topic: Mix and Match  (Read 3410 times)
sanddoc
Mix and Match
« on: November 17, 2017, 01:33:07 PM »
Hello all
   I'm short on funds, and I don't need an FE motor, but  there is a 1960 352 2bbl close to me for $200, I know he will
take way less. He said he thinks the thrust bearing is worn.
   Also close by is a 390 short block,
 I think I can get both for $175, and I was thinking of melding the two together, except for the intake and find a 4bbl
which I see on CL all the time.
   OK, I know all this is really dumb, but when my mind gets stuck on something it is hard for me to give up on
it..
  Any input?
Best
steinauge
Re: Mix and Match
« Reply #1 on: November 17, 2017, 02:06:21 PM »
If you can buy both for that amount of money I would risk it and hope I had a good 390 block and crank. Depending on the year you may or may not be able to use the 352 heads succesfully.
