Author Topic: Main bearings  (Read 4384 times)
ToddK
Main bearings
« on: November 16, 2017, 12:35:42 AM »
I'm trying to find a set of performance main bearings, like the FM 125M, for a crank that is 0.030" undersized. The only 30 under bearings I can find are the full groove style with the feed hole in both the top and bottom shells. Are there any decent performance main bearings available for a 30 under crank?
Re: Main bearings
« Reply #1 on: November 16, 2017, 08:24:21 PM »
There are some by King. Full groove with a round hole, no slot. Only one oil hole too. I just installed some .010's on one of mine. They look decent for the money. FWIW:
https://www.summitracing.com/parts/kgb-mb559am030
chris401
Re: Main bearings
« Reply #2 on: November 16, 2017, 10:06:50 PM »
Were those half groove bearings out of production for a while? Around 2000 I was not online but was on the phone looking.
ToddK
Re: Main bearings
« Reply #3 on: November 17, 2017, 02:34:57 AM »
I have a set of the King MB559AM030 bearings, they are full groove with 2 oil holes. I think the problem is that the crank is 0.030" undersized, there seems to be a wider range of bearings available for STD, 0.010" and 0.020".
I will just go ahead and use the bearings I have, I'm not expecting this short motor to see much over 6500rpm.
Re: Main bearings
« Reply #4 on: November 18, 2017, 01:46:08 PM »
Well, I lied. I took a look at a spare set of King .010 bearings I have, and they do have two oil holes. My bad.
