Author Topic: Steel cranks  (Read 3810 times)
Steel cranks
« on: November 12, 2017, 01:56:23 AM »
Scat v RPM
Availability (typical wait time)
Scat $ v RPM $ + touch up
best source.  Can't find price on scat, best price on RPM looks to be directly from them.
Re: Steel cranks
« Reply #1 on: November 12, 2017, 05:17:57 AM »
What stroke?
An RPM crank, even cleaned up, will be cheaper than a Scat.
Re: Steel cranks
« Reply #2 on: November 12, 2017, 06:31:29 AM »
What stroke?
110% correct.
And the Scat would still be nicer....
But Scat does not make the 3.98 or the 4.375 in a catalog version.  Only 4.125 or 4.250
Scat will cut you other sizes from a semi-finished forging, but at closer to 2 grand...
Re: Steel cranks
« Reply #3 on: November 12, 2017, 01:50:19 PM »
I'll be useing 6.700 rods. Will this limit me to  4.25 crank max ? Would the 4.375 have to use a 6.800 to get piston to crank clearance ?
Re: Steel cranks
« Reply #4 on: November 12, 2017, 02:17:14 PM »
You can use a 4.375 crank with a 6.700 rod.  It uses a custom 1.260" compression height piston.  It will clear the counterweights just fine.
