Author Topic: Baby FE build - 71 F-100  (Read 73415 times)
« on: June 26, 2012, 07:43:35 AM »
I caved and decided to spend a little money and build a 418
- Same block, .040 overbore, torque plate honed, square decked .015 cut
- SCAT 3.98 crank, for 9.97:1 compression, .010 deck clearance, internally balanced
- Les Schmader is going to port the D2TE-AA heads, gasket match to 1247, 2.09/1.66 undercut stem valves, light retainers, 110 closed, 280 open, end stands, Viton seals.  He says to expect 270 cfm
- Worked Edelbrock RPM intake (off my 489 from its pre-EFI days) and a 1 inch spacer blended to match the intake
- 750 Holley (although I may try my 1000 HP series vac sec off the Mustang for fun)
- Same 270H cam but straight up instead of 4 degrees advanced, hoping it'll make power to 5200  ::) with the head work and good intake
- Hedman Headers
- Recurved Duraspark
- 3 inch mandrel bent duals with 50 series Deltaflows
The truck has 33 inch tall tires, a 4 speed, and 3.50s, it weighs 4100 lbs, thats why I stayed with the mild cam.
Should be a hell of a difference from the 8:1, Street Dominator unported combo it is replacing.
Although in its defense, that motor was sure an overachiever, it did everything well for years and ran hard even though it shouldn't have LOL
I built it in either 89 or 91, I cant remember and it was clean as a whistle, no blowby or ridge, bearings still look new, but it was 8:1 and .130 in the hole .....
Going in the 71, which is currently down to a bare frame getting some shiny back on it :)
Re: Baby FE build - 71 F-100
« Reply #1 on: June 26, 2012, 10:37:20 AM »
Should be a another great overachiever.  :D
« Reply #2 on: June 26, 2012, 11:32:20 AM »
I had a '70 F150 4X4 back in the late 1980s.  Another one of those vehicles I should have never sold.  Mine only had a 360, though.  Great looking truck, Ross, can't wait to see it in paint and with the new FE 8)
Chad D
« Reply #3 on: June 28, 2012, 08:22:43 AM »
Looks like it will be lots of fun!  I love that series of truck, had a few of them, always tough.  What are you using for rods/pistons?
« Reply #4 on: July 04, 2012, 03:59:06 PM »
Made a little change
Going to be a 445  8)  SCAT crank and rods, Probe pistons, all else the same ;)
« Reply #5 on: July 04, 2012, 04:57:54 PM »
Ha!  I see you are moving in the right direction... 8)
« Reply #6 on: July 08, 2012, 10:10:34 AM »
I am counting on Les to get me some airflow  :o  The cam is pretty little, 224 @ .050 and .519 lift, I'll rock it back to 110 and cross my fingers.
More intake, head flow, carb, and a smidge more cam than a CJ, hoping it'll hang it past 5000, which would let it rev good enough for the combo, but whether the whole package will actually feed the added cubes the way I want it too is the question
If not, this winter it'll get more cam :)
« Reply #7 on: July 30, 2012, 06:22:23 AM »
Well, not an engine update, but one step closer to having some color!
KMcCullah
« Reply #8 on: August 16, 2012, 02:27:21 PM »
Looks good Ross! Not too much rust around the skirts. The chrome around the windshield ate my lunch on my 72. I will pay big$$$ to have somebody else replace the winshield next time.
With your 445, are you keeping the D2 heads for the exhaust ports?
Kevin McCullah
« Reply #9 on: August 16, 2012, 02:53:26 PM »
I am keeping the D2s for that reason, it has a pretty set of coated Hedman headers and I didn't want to cut them up
Les Schmader said he has my D2s to where they'll kick a stock Edelbrock's butt LOL  His quote not mine.  Apparently 270-ish CFM at my cam lift but we'll see, I dont have them back yet, they should be here early next week.
I went with CJ sized aftermarket valves, some chamber work, port match to a 1247 gasket, so we'll see!
BTW I agree on the glass removal with the chrome, what a PIA!
KMcCullah
« Reply #10 on: August 16, 2012, 07:47:06 PM »
 270ish at .519 seems really good for D2s. I wish I could afford Mr Les. One things for sure, more cam will make a noticable difference if needed.
Our head work sounds identical. After all my work, I'm hoping for 285ish at .600ish out of my C4s. I'm trying to make up for my local altitude. 4500ft approx.
I love the red, are you keeping that color?
Kevin McCullah
« Reply #11 on: August 16, 2012, 08:19:31 PM »
I am, thats the factory Candy Apple color.  Matter of fact, just got back from the shop, the cab is ready for paint except for firewall.  it and the rest of the pieces should be painted by the end of the week and I can start reassembly
I think 280s are reasonable for worked C4s, an FE Forum  friend named Rob Needles had a set done by Les and they were in the 280s and really nothing fancy, just a good port and valve job.
I actually considered welding up a set of used Edels for the truck, but then decided it would be too much hassle for a 5000 rpm stroker LOL
« Reply #12 on: August 24, 2012, 04:54:48 PM »
Some pretty pics
Cab has not been cut and buffed yet, the last shot has :)  I had some time today so all the bolt on parts are finished and waiting in the attic.  (BTW Mrs Stang saw this pic by phone and asked if the parts were in our bedroom LOL, close, attic off the walk in closet)
It's looking very pretty, and should look even better with a fresh 445 under the hood!
Chad D
« Reply #13 on: August 24, 2012, 04:54:02 PM »
Pretty indeed!
KMcCullah
« Reply #14 on: August 27, 2012, 10:02:47 AM »
Sweet! I love that color! Can't wait for Martha Stewart to see how nice that color looks indoors. There's gonna be a new line of paint at Kmart.  ;D
Kevin McCullah
