Author Topic: Quickfuel 735cfm SS series VacuumSecondary  (Read 4692 times)
« on: October 23, 2017, 08:41:09 PM »
Great carburetor. I rebuilt and detailed it, made sure it's perfect. Should be bolt on and with a few idle screw adjustments will be ready to roll. Mild cloudiness in the aluminum. Still looks great tho.
$400 shipped
Re: Quickfuel 735cfm SS series VacuumSecondary
« Reply #1 on: October 24, 2017, 11:08:20 AM »
Perfect for me Drew I'll take it.
PayPal?
« Reply #2 on: October 24, 2017, 12:25:51 PM »
Sure, I'll msg you.
Guess we'll consider it Sold.
« Reply #3 on: October 24, 2017, 12:29:08 PM »
Yup
« Reply #4 on: October 24, 2017, 12:30:28 PM »
For your records the calibration is as follows:
The only difference from the factory setup are the needles which I replaced with high quality .097 needle/seats.
List number      Quickfuel 735cfm SS
Type         4150 VS
Primary
Float         Center Hung Nitrophyl
Booster         Stepped Downleg .152
Pump nozzle      .031
Pump type and cam   30cc, blue cam #1
Idle air bleed      .070
High speed bleed   .035
Metering block#      NA billet
Main Jet      68
Power valve      6.5in 4window
PVCR         .052
Emulsion      3 @ .028
Kill Bleed      Cross channel .028
Idle Feed restriction   .032
Needle and seat      .097
Venturi size
Throttle plate size   1.685
Secondary
Mechanical or Vacuum?   VS
Spring color      Adjustable pot
Diapghram length   NA
Float         Center Hung notched
Pump Nozzle      none
Pump type and cam   none
Idle air bleed      .070
Metering block/plate#   na
Idle Feed Restriction   .032
Jet size      78 with jey extensions
« Reply #5 on: October 24, 2017, 12:50:05 PM »
Thanks for the info.
« Reply #6 on: October 24, 2017, 01:09:05 PM »
BTW Drew I'll be in the market for a 950 pretty soon. No hurry, but if you happen to run across a good deal I'd rather buy one through you and save a few pennies over new.
