Author Topic: moisture in valve cover breather cap  (Read 5782 times)
« on: October 17, 2017, 02:51:07 PM »
i have moisture in my cap and a little smoke or steam coming out of my passenger side valve cover breather cap.i dont know if this is an issue,i just had the intake off and i have not changed the oil yet.i thought a little water may have drained into the engine when i removed the intake manifold. i need some opinions.
Re: moisture in valve cover breather cap
« Reply #1 on: October 17, 2017, 03:01:18 PM »
Take a long drive, say 1 hour, highway or not. Park it, check it. Then, check the next day before fire-up (local humidity, day/night could affect it too as the engine cools, especially if the car is on grass, not concrete).
How hot is the engine with the t-stat open? Low temps will do that too...........
« Reply #2 on: October 17, 2017, 03:17:31 PM »
car goes on a lot of short drives.im in a high humidity area too.temps around 175-180,but like i said i go on alot of short trips where the stat dont always have time to open,and when it does open,its not open long.
« Last Edit: October 17, 2017, 04:29:35 PM by fryedaddy »
« Reply #3 on: October 17, 2017, 05:10:28 PM »
short drives give condensation in the valvecovers
you should se here in the winters its like whipcream
in the filler caps
« Reply #4 on: October 17, 2017, 05:19:09 PM »
Yeah, you may need to get the highest rated t-stat you can for an FE. Not sure if a 195F is readily available but it should be.
« Reply #5 on: October 19, 2017, 02:09:46 PM »
ok on the moisture,but what about the trickle of smoke coming out of the passenger side breather cap?
« Reply #6 on: October 19, 2017, 04:06:27 PM »
Could be steam from an internal leak or could be condensate burning off.
« Reply #7 on: October 19, 2017, 05:55:31 PM »
If the oil on the dipstick is not gray take it for a long drive
an hour or so and se if the problem go away check  the color
on the oil now and then and check coolant level during the drive
« Reply #8 on: October 19, 2017, 08:19:34 PM »
oil is clean and the rad is clean too.i guess i will take it for the long ride like Heo said,thanks
« Reply #9 on: October 19, 2017, 08:47:14 PM »
[/quote  could it be steam where i changed intakes and let a little coolant escape when i lifted the intake off the engine
« Last Edit: October 19, 2017, 08:49:23 PM by fryedaddy »
