Author Topic: 9" Motive Gear Performance 3.75 Ring & Pinion set (Reduced)  (Read 3107 times)
Tony Fritz
« on: October 16, 2017, 09:01:08 AM »
I have a New Motive Gear Performance Ring & Pinion set #F890375 for sale. It was removed to change gears and has NO miles on it. It is a Performance Off-Road gear set made from 8620 hardened tool steel and then REM finished that looks like chrome. 3.75:1 ratio, 45 ring gear teeth & 12 pinion gear teeth, 28 spline pinion. New from Summit is $314.00 + $150.00 REM finishing. Will sell for $300.00 + shipping. Can deliver to the Columbus, OH Ford Swap or the FE Race & Reunion. Call (513)616-3503. Can text pictures if needed.
« Last Edit: October 26, 2017, 08:09:24 AM by Tony Fritz »
