Author Topic: Crossram..C8OE-N heads...FE intake adapter Tunnel ram  (Read 3672 times)
JoeW
« on: October 11, 2017, 08:38:33 AM »
Edelbrock Crossram...1300 dollars
Fe Powernet adapter with a 351C strip dominator intake and a Weiand 351C Tunnel Ram intake ....1300 dollars
Both the 351C intakes have been modified to run on the adapter
9D3 and 9F3 date code C8OE-N heads SOLD
Here are the specs on the parts
Comp cams 933-16 springs
Comp cams 4700-16 spring seats
Comp Cams .500 viton seals
Comp Cams 749-16 Chromoly Retainers
Comp Cams 612-16 locks
Installed height 1.935
175LBS @ 1.935
490LBS @ 1.300
Guide clearance .0026 intake and exhaust
.060 shim on intake only
SBI exhaust seats
A light port and polish was done to the heads
No flow numbers are available
blow the heads off and they are ready to run
The heads came out of the machine shop on 8/16/17
but my plans have changed
I also have a pair of 450CFM carbs for extra money
Parts are located just south of St Louis
tnlprt at hot mail dot com
« Last Edit: October 15, 2017, 06:46:50 AM by JoeW »
