Author Topic: 8 sleeves in a side oiler ok ?  (Read 5922 times)
427HISS
« on: October 01, 2017, 02:41:09 PM »
A guy has a side oiler for sale that has all cylinders sleeved. Never hurt. He want's $1,000.
I've never had a sleeved motor, but with new cars with alum. blocks with steel sleeves, isn't that the same thing ?
427 Side Oiler Block.
 4.160 bore
   3.98 stroke
=428ci
Here's what he told me.
"I race Stock eliminator, usually most guys use the 427 cross bolt blocks and sleeve them because they are stronger than 428. I just went 10.67 @3280#. With this block. I just have too many engines".
Link to ad-
https://m.facebook.com/groups/611279935626513?view=permalink&id=1460892260665272&comment_id=1461752200579278&notif_t=group_comment_reply&notif_id=1506866927402427&ref=m_notif
« Last Edit: October 01, 2017, 02:44:44 PM by 427HISS »
Re: 8 sleeves in a side oiler ok ?
« Reply #1 on: October 01, 2017, 03:42:55 PM »
It kind of depends on the sleeves, but in most cases it is definitely not OK.  Generally two adjacent sleeves in a block will split the block at the deck eventually, leading to head gasket failure and coolant in the oil.  There are some engine builders who will sleeve down a 427 block to 390 bore size, but taking a minimum amount out of the stock 427 bore.  What is the bore size of the block?  If it is stock 427 size (4.23"), or bigger, I think that block is headed for failure.
« Reply #2 on: October 01, 2017, 04:12:20 PM »
i had a 390 with eight sleves.i drove it to work every day for 8 years,and every now and then for about eight more,then it did what Jay said
« Reply #3 on: October 01, 2017, 04:35:48 PM »
You got a lot more life out of yours than I would have expected...
427HISS
« Reply #4 on: October 01, 2017, 07:30:21 PM »
Well, I won't take the chance, I'll look for a different deal.
« Reply #5 on: October 01, 2017, 07:35:30 PM »
Sorry, I didn't notice the bore you posted at only 4.160".  This is probably one of those blocks that I mentioned that has been sleeved down, so it may be OK.  If you can find out how much the 427 block was bored to for the sleeve, and it isn't over 4.26 or 4.27, the block is probably OK.
427HISS
« Reply #6 on: October 01, 2017, 08:46:34 PM »
Ok, I'll get a hold of him and ask those questions.
427HISS
« Reply #7 on: October 02, 2017, 10:48:13 PM »
The block is filled, for drag racing.
« Reply #8 on: October 03, 2017, 08:41:32 AM »
Not sure about FE, but a 351C - no way.  The cylinder cores are what supports the deck and with sleeves, I'd think the deck would washboard like a gulf coast highway.
427HISS
« Reply #9 on: October 05, 2017, 10:03:49 PM »
Lol,...washboard like a gulf coast highway. Funny sh** !
