Author Topic: Rocker stand bolt spacing  (Read 4831 times)
scott foxwell
« on: September 20, 2017, 02:17:30 PM »
Does anyone have the rocker stand bolt spacing dimensions for the FE heads?
TIA
bluef100fe
Re: Rocker stand bolt spacing
« Reply #1 on: September 21, 2017, 10:49:23 AM »
I believe the spacing is 4.625 for the end cylinders, unsure of the spacing between the middle cylinders 2 and 3...
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
comet2
« Reply #2 on: September 21, 2017, 10:59:32 AM »
scott i got 4.640 on ends 4.970 middle with calipers since i was measuring  pulleys
scott foxwell
« Reply #3 on: September 21, 2017, 11:26:54 AM »
I did some reverse engineering last night and came up with similar numbers. Thanks.
« Reply #4 on: September 21, 2017, 11:41:37 AM »
The end ones should be the same as FE bore spacing, 4.630".
scott foxwell
« Reply #5 on: September 21, 2017, 01:21:57 PM »
Exactly! That little light just came on... ::)
