Author Topic: On Head FE Vvalve Spring Tester  (Read 5184 times)
smokin427
« on: September 13, 2017, 11:27:23 PM »
Does anyone know of a valve spring tester that I can use without removing the springs, just the rocker shafts. I have 700 lb springs on my solid roller in my 427 FE 64 Falcon Sprint
jimeast
Re: On Head FE Vvalve Spring Tester
« Reply #1 on: September 14, 2017, 05:20:02 AM »
Not quite what you are asking for, but I think it's an eloquent, inexpensive solution to removing and installing your springs.  Looks like an FE guy designed and manufactures this.  Maybe someone on the forum knows him.
http://www.ebay.com/itm/Valve-Spring-Compressor-Ford-FE-390-427-428-Cobra-Jet-Mach-1-Shelby-/263193719838?hash=item3d4791741e:m:mTOEokGjjrI1HKVObBD73mA
« Last Edit: September 14, 2017, 05:23:52 AM by jimeast »
« Reply #2 on: September 14, 2017, 05:47:21 AM »
Its a good tool and works well. Tim makes a few great products for the FE.
scott foxwell
« Reply #3 on: September 14, 2017, 07:30:03 AM »
It wouldn't be hard to adapt something like this; this is a ProForm el-cheapo but the one from LSM (best one made IMO) is almost identical.
jimeast
« Reply #4 on: September 14, 2017, 10:36:38 AM »
Neither of these have gauges that go to 700lbs
scott foxwell
« Reply #5 on: September 14, 2017, 11:21:11 AM »
You're checking seat pressure, not open. You don't need 700#.
jimeast
« Reply #6 on: September 14, 2017, 11:34:17 AM »
Thanks, I would have assumed you would check pressure throughout the range.
