Author Topic: Engine plate pattern.  (Read 5353 times)
428 GALAXIE
« on: September 13, 2017, 05:23:19 AM »
Does anyone have drawing of the engine plate. Intressed of the starter location and the starter bolt hole locations.
If someone has blueprints or made their own accurate measures and dxf or similar drawings it would help.
I will do my own measurements later but I could sketch some of my idea's.
What am I doing well look powermaster starter and then look Toyota 3.0 diesel starter and then look again the powermaster.
Mikko
Re: Engine plate pattern.
« Reply #1 on: September 14, 2017, 02:20:11 PM »
Well, since nobody else answered...
I'd hit a junkyard with some heavy paper and a few lead pencils to copy a plate's dimensions with a rubbing:
https://en.wikipedia.org/wiki/Stone_rubbing
Or, plop a FE block nose down, paint the clutch side's perimeter with a coat of cheap white paint and press on a piece of heavy cardboard to make a transfer copy.
« Last Edit: September 15, 2017, 07:31:28 AM by machoneman »
« Reply #2 on: September 14, 2017, 02:40:22 PM »
what i can do if you dont have a lose blockplate
i can transfer a blockplate to a paper and post it
cant cost that much to finland from sweden
428 GALAXIE
« Reply #3 on: September 15, 2017, 07:00:04 AM »
Thanks Heo I'll keep that in mind.I have to yank the transmission out anyway at some point and then I can mock up the starter.
Little ot but having those days that makes you yell douughh.
Fixed girllfriends shirty Citroen yesterday had to connect the jumper cables from my daily driver didn't drop the hood down as normally.Left to work this morning and you guys know what happened next when got to bigger road.Well smashed windshield and big reversed aero bubble in the hood.
Dough!!!!!!!!
Mikko
428 GALAXIE
« Reply #4 on: September 15, 2017, 11:19:50 AM »
And the shitty Citroen just died in traffic lights.
Sorry about the serious OT. ..........
Mikko
« Reply #5 on: September 15, 2017, 03:22:35 PM »
I feel for you. I Did that to my wifes 500sec Mercedes...The Aluminium hood was not
so nice after that :(  .... the wife was not nice either ::)
But with the starter ...coggs meassured in inch uses Pitch and cogs meassured in metric
uses module but with a Japanese car you can not bee sure what they use so if the starter
cogs and the Ford cogs match im not sure..........
« Last Edit: September 15, 2017, 03:45:23 PM by Heo »
428 GALAXIE
« Reply #6 on: September 15, 2017, 10:17:05 PM »
Wondered teeth match earlier too.Starter gear is so rounded that it shouldn't bee so picky.This is kind of shot in the dark thing.
Time or money wise this ain't sensible just something to tinker at work while machine runs it's program.
Mikko
« Reply #7 on: September 17, 2017, 10:51:16 PM »
The Powermaster and other Nippondenso starters are for normal Japanese cars , just adapted to US engines. The Ford permanent magnet starters work too. Any 4 banger or V6 can be adapted. I used a 3.0L V8 one mounted upside down on my FE. I had to do some grinding on it and weld the ears to clock the solenoid away from the block.
