Author Topic: FE Parts  (Read 3532 times)
garyv
FE Parts
« on: September 11, 2017, 09:15:33 AM »
I have some high quality parts left over from my 2 previous 465 cube Tunnel Port builds.  They have dyno time only.   Shipping in the continental US is included in the price just to make it a little easier on me so I don’t have to run back and forth to UPS etc.  Preferred payment by USPS money order.  I will take a personal  check and will ship after it clears the bank.    Remember prices include shipping !     Click on my name for E-mail address.
I have 2 sets of Diamond Custom Pistons with pins, will need spirolox.   Both are for 3.98 stroke.
1.   Bore 4.310, Compression Ht. 1.360, Ring pack .043, .043, 3.0 – these were for a pump gas build that made 605 HP.  $500.00  The first cam and springs listed below were used in this build.
2.   Bore 4.310, ring pack same, I don’t have sheet on them but they were for 12:1 compression and were just switched out for the ones above. Pins included and still have the rings on them.  Cam was changed and we made 700hp with them.  $500.00
3.   Bullet branded Morel  Solid Roller Lifters. Needle Bearing/Pressure Fed $ 495.00
4.   Set of 3/8 stem Jet Flow valves, 2.25 intake/1.75 exhaust .  Originally purchased from DSC.  $200.00
5.   Bullet Solid Roller Cam,  Duration @ .050 260 int./270 exh.   ICL 104 and LSA 106, 625/650 lift  $275.00
6.   Valve springs for the Bullet Solid Roller are PAC. 280 seat/ 630 open.  $225.00
7.   Comp Cams Solid Roller Cam, 260/270@.050, 108 LSA,  Lift 742/750, LSA 104.  $275.00
8.   Valve springs for the Comp Solid Roller.  PAC 1300 series endurance springs, 265 seat, 636 open,  I think these were more like 660 open but can’t find the card but they worked great  with this cam.     $ 275.00
9.   Trend push rods 9.00 length  ball/cup, wall  0.135   $215.00
10.   Trend push rods 9.150 length ball/ball –for T&D Rockers , wall 0.105 $ 215.00
