Author Topic: what needs done to 391 FT block to replace a 428 car block?  (Read 6590 times)
jholmes217
« on: September 09, 2017, 05:08:34 PM »
Besides a bushing for the distributor, is there anything else that needs done to this block to run it in the place of an FE?  My 428 CJ in my 1969 Mach 1 was already bored .060 when I bought the car.  There is a 391 FT short block for sale close to me for $150.  I don't know if it has "428" in the water jackets or "C" scratch on the back.  I plan to just use the block, not the rest of the FT rotating assembly.
« Last Edit: September 09, 2017, 09:24:28 PM by jholmes217 »
Jeff
4 speed, 3:50 traction lock
Olympia WA. area
Re: 391 FT block
« Reply #1 on: September 09, 2017, 05:42:03 PM »
FT blocks usually have an oil return hole on the bottom side near the oil pan rail that was for the air compressor. It can just be plugged with a pipe plug.
jholmes217
Re: 391 FT block
« Reply #2 on: September 09, 2017, 09:24:49 PM »
Thanks.
Jeff
Olympia WA. area
Lowrider
Re: what needs done to 391 FT block to replace a 428 car block?
« Reply #3 on: September 11, 2017, 07:19:30 AM »
Not a 428, but I used a FT block to repair a 406. I found the deck height with the FT left the pistons waaay more in the hole than I wanted. I think I had 0.015-0.020 taken off the deck and the pistons ended up where factory 406/427's in a FE block sat. Don't recall what the spec was.
BH107
« Reply #4 on: September 11, 2017, 09:07:01 AM »
Not sure about your combo, but 406 pistons were way down in the hole from the factory. All FE/FT blocks have the same deck height.
BH107
« Reply #5 on: September 11, 2017, 09:07:45 AM »
It's a gamble, and definitely have it sonic tested first. Not many will go to 4.13 bore without being thin.
Lowrider
« Reply #6 on: September 12, 2017, 06:46:01 AM »
Found the specs over on mercurystuff.com. 406 was .045-.065 IIRC that's what I measured before tear down. After taking .015/.020 off I got to the lower spec or just a few thousand more. This FT block must have had a hard life as it had a twist to it. End result is it runs fine, doesn't spark knock or overheat here in the Az. desert.
