FE Technical Forum
390 USING OIL AND WATER
Topic: 390 USING OIL AND WATER (Read 4406 times)
September 06, 2017, 10:55:42 AM »
My uncle has a 390 that he had freshened up,new rings,gaskets,etc.it seems to run ok but after a few days he has to add oil and coolant.its not mixing them,its just using.
1966 comet caliente 428 4 speed owned since 1983 1973 f250 ranger xlt 360 4 speed papaw bought new
chilly460
Re: 390 USING OIL AND WATER
Reply #1 on:
September 06, 2017, 11:31:12 AM »
What intake gaskets did he use?
Reply #2 on:
September 06, 2017, 02:33:20 PM »
Quote from: chilly460 on September 06, 2017, 11:31:12 AM
felpro,you think it is his intake seal?after about 50 miles of driving,you have to put in a quart of oil and a quart of water
Reply #3 on:
September 06, 2017, 02:59:46 PM »
That's the first suspect on an FE.....
Have him pull the spark plugs and see if he can narrow it down to any particular cylinder.
Instagram: brentlykinsmotorsports
YouTube: Lykins Motorsports
Reply #4 on:
September 06, 2017, 10:36:28 PM »
thanks,i will tell him
jholmes217
Full Member
Reply #5 on:
September 07, 2017, 10:56:22 AM »
Did he bend down the head gasket tabs and has he re-torqued the intake manifold bolts after a couple heat cycles, and then again after a few more heat cycles? I've learned the hard way on both of those.
Jeff
4 speed, 3:50 traction lock
Olympia WA. area
FE Technical Forum
