Author Topic: Shoe type factory rocker geometry  (Read 13142 times)
scott foxwell
« on: August 13, 2017, 01:14:07 PM »
Anyone here ever messed with the factory shoe type rocker geometry?
Rocker geometry is a real pet peeve of mine and I have a pretty good handle on roller rocker geometry, but the shoe type rocker really throws me.
With a roller tip rocker, the goal for proper geometry is minimum sweep across the valve tip, or 90* geometry where the effective centerline of the rocker is 90* to the valve at mid lift. For reference, this is what we try to achieve with a roller tip rocker:
With a shoe rocker, I'm not sure exactly what the goal is. One thing for sure, the ratio will change throughout rocker movement and you can alter that ratio a LOT by changing geometry (raising or lowering the stands). With a roller tip rocker, the distance from the center of the pivot (trunnion) to the center of the roller tip is fixed and for all intents and purposes, so is the contact point. Not so with a shoe rocker.
I can bench set-up a shaft roller rocker system on the head to get the perfect geometry. All I need to know is the lift, but that doesn't seem to be the case with shoe rockers. I did some experimenting last night with my FE heads and stock rockers. The first thing I thought I;d do was set up where the contact point of the rocker was my reference, and I;d set up the stand height so that a straight line from the center of the shaft (fulcrum, pivot, whatever you want to call it) to that contact point was 90* to the valve at mid lift. This sort of made sense intuitively.
Here's what I mean;
This pic shows the valve at half lift and where the rocker sits now. I use the top of the retainer as a reference to my 90* to the valve relationship. You can see that if I wanted to achieve my goal, the stands need to come down some. I can actually figure it mathematically since I can measure the height of the valve tip off the rocker pad but this is good enough for illustration purposes.
At this setting, I put some gear pattern grease on the tip of the valve and looked at the sweep pattern. This is what I get:
WIDE pattern on the valve. Centered, but WIDE. Well, I thought that was probably just a function of the way the shoe worked on the valve. Then I started moving the rocker and valve through it's motion and watching the tip. The shoe starts way back on it's heel, and as the valve opens, moves to the toe. Big time. Looking at it from a geometry stand point, this HAS to be changing the ratio, a LOT.
What I need to do is put this on a block with the cam and compare lobe lift to valve lift and record the ratio changes. I'll get to that. But for now, I'm just looking at the sweep on the valve tip and I'm wondering if I can change that, or if it will stay this way because of the shoe design. In my mind, I sure would like to reduce all that sweeping motion if I can.
So knowing I can't go shorter (without cutting rocker stands) to get my desired setting, I figured let's see what happens when I start ADDING stand height, just for reference.
These next pics will go in .030" increments all the way to .120".
Raised .030"
.060"
.090"
.120"
I can see that by the time I added .120" of shim, the pattern definitely got narrower. (Notice, the contact on the rocker never seems to change much but does seem to get narrower as well). Less sweep means less side loading on the valve and less guide wear, less overall friction but when I start looking at the position of the rocker and how it acts on the valve, I'm not nearly convinced this would be better. The problem is, I really don't know what "right" is for a shoe rocker, and what operating parameters an engineer is shooting for when designing around one. The other thing to consider is the push rid side of the rocker and I know what the correct geometry is on that side. Maybe that will be the deciding factor. Next step is to get the head on a block, cam in with lifters and see what the lift curves look like. I just thought this might be a fun discussion for anyone interested.
« Last Edit: May 11, 2018, 10:54:24 AM by scott foxwell »
Re: Shoe type factory rocker geometry
« Reply #1 on: August 13, 2017, 01:40:15 PM »
I do it the same way I do roller tip rockers:  minimize the sweep.
I usually end up with at least a .060" shim with factory style rockers and the valves that I use here.  On engines with billet end stands, that requires making a long shim so that the entire end stand is supported.   You will have a much wider pattern than a roller tip.  Hard to get away from it.
Make sure and choke your adjuster way up.   You'll probably find that you can make a cup pushrod end clear the rocker arm with either zero or only one thread showing on the adjuster.
scott foxwell
« Reply #2 on: August 13, 2017, 01:43:55 PM »
Thanks for that. I feel like if I keep adding shim the pattern will get narrower and narrower but I also know that moving too far away from the center of the arc isn't a good thing...not sure where to stop.
The other thing is, you could change the radius on the shoe and the rocker would act completely different. I wonder how they calculate what radius to use on the shoe. It's like a little cam lobe all of its own...
« Last Edit: August 13, 2017, 01:47:09 PM by scott foxwell »
« Reply #3 on: August 13, 2017, 01:46:34 PM »
I'd wait until you get the engine mocked up and see if you're losing any lift.
scott foxwell
« Reply #4 on: August 13, 2017, 01:48:58 PM »
Yep. I know what the cam designer wants so I'll probably set it up to get as close to that as possible.
66FAIRLANE
  • Andy
« Reply #5 on: August 13, 2017, 11:46:30 PM »
I thought you would want the adjuster pretty much where he has it. Straight line between tip pivot point, shaft pivot point & pushrod pivot point. Any movement either way in the adjuster and you would start to loose rocker ratio.., no?
« Reply #6 on: August 13, 2017, 11:53:37 PM »
In that first picture i'd rather have the rocker closer to the center at max lift and not worry where it is with the valve closed and no pressure.
« Reply #7 on: August 14, 2017, 04:12:10 AM »
On the engine in full running form, the pushrod will not be in line axially with the rocker arm adjuster.  So if the adjuster is hanging way down, your pushrod end spends time dancing back and forth instead of translating all movement to the valve.  The closer it is to the rocker body, the less wasted movement.  Obviously you can't get it too close or the pushrod cup makes contact.
« Reply #8 on: August 14, 2017, 06:05:13 AM »
You will also find that the pushrod tube will contact the rocker body as you back the adjust up.  Some detailing on the rocker casting helps.  That noted, backing the adjuster up is the right idea as far as lift goes.  When its way down the pushrod will sweep "in and out" a lot getting into trouble with the intake hole and side loading the cup.
scott foxwell
« Reply #9 on: August 14, 2017, 08:10:56 AM »
There is an "ideal" geometry for the pushrod side that follows what I do with the roller tip rocker on the valve side. The center of the ball on the pushrod end is the pivot point. You want an imaginary line from the center of the shaft through the center of the ball, to be 90* to the pushrod at mid lift. Same as the valve side. I would want the adjuster out as little as possible just to maintain rigidity but it I'll set them up with the geometry as close as I can get it.
scott foxwell
« Reply #10 on: August 14, 2017, 08:13:31 AM »
Thanks Barry. I'll look out for that.
What are your thoughts on the valve side of things?
« Reply #11 on: August 14, 2017, 03:57:58 PM »
At least drop down to an 11/32 stem - valves are really long at +/- 5.425, so they are heavy.
You can get a big intake in there but the exhaust gets tight against the wall - a 1.720 will physically clear on a 4.070 bore but will scrub the wall when its running - I would not go past 1.680 anymore
scott foxwell
« Reply #12 on: August 15, 2017, 10:35:19 AM »
I have 2.05 and 1.65 11/32 x 5.425 valves from REV. The only down side is they have a /25 tip so while you have PLENTY of installed height, you have to use a -.05 lock to clear the retainer. FWIW this is pretty much standard length for BB Chev valves I use and they run anywhere from 2.25 to 2.35 int, and 1.88 ex. THOSE are heavy. These FE valves...they're not heavy. ;)
Ford428CJ
  • FE FREAK!
    • Hillside Auto
« Reply #13 on: August 16, 2017, 07:47:13 AM »
I end up using .060 shims with POP or stock stands. Blue Racer rockers with this set up.
Wes Adams FORD428CJ
64 Falcon 428FE
scott foxwell
« Reply #14 on: August 16, 2017, 08:28:40 AM »
That looks good but you're talking about a roller tip rocker. Factory shoe rocker is altogether different.
