Author Topic: Streetmaster Intake leaking oil from an intake bolt?  (Read 4635 times)
jholmes217
« on: August 12, 2017, 01:53:58 PM »
I put a Streetmaster on my 428 about a month ago. I keep finding a small pool of oil in the area around the second from back on the drivers side intake bolt. This is one of those bolts that is hard to get a wrench on because it is so close to the runner. The bolt has a washer on it (ARP intake manifold bolts set.)
Has anyone had this issue, and if you did, how did you fix it?
Jeff
4 speed, 3:50 traction lock
Olympia WA. area
Re: Streetmaster Intake leaking oil from an intake bolt?
« Reply #1 on: August 12, 2017, 02:34:31 PM »
Are you sure it isn't the valve cover gasket?
jholmes217
« Reply #2 on: August 12, 2017, 03:44:35 PM »
Pretty sure.  Ran a shop towel along the valve cover area and it was pretty clean.
Jeff
Olympia WA. area
jholmes217
Fixed! Cure in my comments in case anyone else has this problem.
« Reply #3 on: August 12, 2017, 04:39:45 PM »
Fixed!  I ground one edge of a washer flat so it could bottom out on the runner side of the intake manifold, then used a little "The Right Stuff" on the intake side of the washer, and went for a test drive.  Leak fixed!  Thanks to Larry H and Chris McAlpine for the suggestion on the other FE forum.
Jeff
Olympia WA. area
« Reply #4 on: August 12, 2017, 06:46:10 PM »
I was wondering if maybe it wasn't sitting all the way down.
I figured you already checked that.
Good catch.
« Reply #5 on: August 13, 2017, 03:42:28 PM »
On My streetmaster i made a "tool" to spotface each boltholes
And used a washer under each bolt . The first tool i made
Same dia as the washer since i thought the holes
would be in the right place. They where of a lot i ended up
With having to file one hole oval to be able to center the dist.
In the Pic is the cutter i made from some toolsteel i had .it cut
aluminium without heattreatment. I made tooths on the side of
The cutter for those holes close to the runners. Next is the bushing
with a light pressfit for the bolt hole and next is the M8 bolt that
the cutter is threaded for. So i hammered the bushing Into the
hole from the bottom inserted the bolt threaded the cutter on the bolt
And just rotated it with a ratchet and Held a light pressure on the
Cutter
« Last Edit: August 13, 2017, 11:36:19 PM by Heo »
