Author Topic: Stainless header bolts?  (Read 14331 times)
« on: August 03, 2017, 01:02:45 PM »
For decades I have always used regular old Mr. Gasket, and more recently, ARP black steel header bolts, never had any issues with them. However, my FPA headers came with a set of shiny stainless steel header bolts, but I am wondering if I should use them. I have heard some people say that stainless steel bolts tend to gall up and seize , especially in high heat applications. Any body know if thats true or an old wives tale? I`d hate to find out the hard way! This is with factory cast iron heads, if that makes a differance. Thanks.
JamesonRacing
Re: Stainless header bolts?
« Reply #1 on: August 03, 2017, 01:14:40 PM »
I've used stainless ARP bolts on all my FE engine headers for years without issue.  Think you're safe to use them.
« Reply #2 on: August 03, 2017, 01:28:51 PM »
I've been using the ARP stainless header bolts for decades on cast iron heads, no issues, but I do use anti-seize.
bill_396
« Reply #3 on: August 03, 2017, 01:44:27 PM »
Maybe okay on cast iron but I'm not sure I'd use them in a head with thread inserts. We have all kinds of issues with stainless bolts galling and seizing up in tools that see temperatures less than four hundred F. We try to always pitch the stainless and use alloy bolts before they come out, insert and all.
« Reply #4 on: August 03, 2017, 02:03:39 PM »
I use them with aluminum heads on the dragster - with plenty of anti-seize.
scott foxwell
« Reply #5 on: August 03, 2017, 03:18:23 PM »
The only time stainless is a problem is when it's on stainless. Stainless nuts and bolts, stainless bolts into stainless, etc. Then you're asking for trouble. Stainless into cast iron or aluminum should never be a problem and if you're concerned you can use a little anti seize...but I also agree about being careful with stainless inserts in aluminum. I wouldn't do that.
GJCAT427
« Reply #6 on: August 03, 2017, 06:01:21 PM »
Stainless bolts come in several alloys. The cheapest is the 18-8 which is very common and is junk. I have had them seize with regular steel nuts. Fastenal love to sell these to the unwary. as for bolts that I use in my manifolds I found bronze bolts work very well. I have them in both my 427s with no problems. I do check them ever couple of yrs and they haven`t come loose yet.
« Reply #7 on: August 03, 2017, 06:51:31 PM »
Rory, are you sure they're stainless?  A magnet will tell you for sure.  I recently bought a set of FPAs for my Galaxie and all the bolts provided were a shiny cad-plated steel.  I'm going to replace them with ARP stainless header bolts because here in SE Tx the cad plated ones will turn into little balls of rust in no time.  I've used the ARPs before and they've worked fine with cast iron.  No experience with aluminum yet but I'll make sure and use anti-seize.
Bruce
preaction
« Reply #8 on: August 03, 2017, 09:28:58 PM »
Bronze has a tensile strength of 35,000 psi mild steel is 80,000.
C6AE
« Reply #9 on: August 03, 2017, 11:28:13 PM »
I like Bronze, don't know if I would use it for header bolts, but it can be pretty strong.
"Silicon bronze bolts, hex head, fully threaded with either coarse or fine thread to ASME/ANSI B18.2.1 specifications in alloy 651 for sale on this site. High corrosion resistance and good electrical conductivity. This silicon bronze alloy 651 offers a tensile strength of 70 - 100 KSI and a yield strength of 55 KSI minimum. It has a hardness of 75-95 HRB.
http://www.aaronssiliconbronzefasteners.com/SiliconBronzeBolts.htm
« Reply #10 on: August 04, 2017, 12:36:54 AM »
Bruce, I just ASSumed that the FPA header bolts were stainless steel, based on their appearance. I will check them with a magnet tommorrow, and maybe give Stan a call a FPA a call to see what he says. I kinda like the ARP black header bolts because of the smaller (3/8" hex head) give a bit more wrench room. Problem is, all the local shops have is 3/4" long header bolts, with the thick flanges on the FPA headers, I would prefer to use 1" long bolts.I guess regardless of what header bolts I use, never seize would be a good idea. Thanks for all the replys, guys.
« Reply #11 on: August 04, 2017, 05:40:36 AM »
I've used Stage 8 SS locking bolts w/anti-seize for years in aluminum (SBF) heads and love 'em.
https://www.stage8.com/ford-performance-locking-fasteners/
« Last Edit: August 04, 2017, 06:23:17 AM by machoneman »
« Reply #12 on: August 04, 2017, 06:05:10 AM »
Used ARP stainless for decades without issue in both iron and aluminum heads with inserts.  A blob of anti-seize is always used.
« Reply #13 on: August 04, 2017, 08:04:13 AM »
 My experience of working with stainless for many years in the
industry. Stainless bolt and nut together the least speck of dirt
or sand can make them weld them self together. And stainless
dry in aluminium is a big risk of galling, Where there was heat
involved we used molybdendisulfid (whatewer the English name
is for that)Dry,or mixed with oil where there was no heat
And don't use powertools on stainless bolts, the speed multiply
the risk for seizing
So clean the treads use antiseize and hand tools and you will be fine
Lenz
« Reply #14 on: August 04, 2017, 08:20:21 AM »
SS bolts into aluminum, nickel based never seize, zero problems.  I have wondered some about the copper vs. nickel base for never seize products, I have both kinds and always use the copper on rotors and brake drums and undercarriage hardware before replacing.  Removes the need to haul out the BFH to break them loose later in our salty climate.  Is there a better choice base for different applications or is it a horse apiece?  Don't mean to sidetrack the thread, just curious.
Len Zielinski
'64 Galaxie 500 445 Toploader
'69 F100 300 stick
