Author Topic: FE and related parts - Extremely long list. -  (Read 4534 times)
ntheogen
« on: July 26, 2017, 07:06:31 AM »
Heads:
1. CJ Heads: matched pair of CJ heads. 9M16 & 9M15. New bronze guides. Fresh hardened seats. Good thumbprint left. Freshly surfaced on all sides. Have been welded at
exhaust ports that isn’t to pretty. $700.
2. Complete set CJ heads mismatched 8L8 & 9J22. Never cut. Untouched. Original condtion. $900.
3. Matched set 406 heads 2E3 & 2E7. C2SE-C Heads. One head has 4 broken exhaust bolts. Both heads severely rusted on one end. $250.
4. C7je-a 427 Marine Heads. - $650
5. CJ Heads - Matched set 8k29/8k30 - Completely redone $1150
6. C4ae-h Low Riser heads - 66 date code - Extensive Port work done on these. Very Nice Heads. $1000
7. Single CJ Heads - Hard to read dates - Complete $450 each
Distributor:
1. C5AF-F 427 Transitorized igniton Dizzy. Extremely nice shape, looks almost new. Hard to read first digit of date code. Looks like 6 or 8. New NOS c3AZ-12171-A
Transitorized points in packaging as well. $1350
Crankshafts:
1. C4AE 427 Crankshaft fresh. .020/.030. $350.
2. 3U 427 crank. Needs turned. $200.
3. 428 crank 1U. Needs turned $200.
4. C5AE-6300-C. Cross-drilled $ crankshaft. Standard - $550
5. 1U 428 Crank. .020/ .020. Fresh. $400.
6. Scat 427 stroker rotating assembly. Freshly Turned .010/.020 3.98 crank. Scat rods with ARP8740 bolts. H Beam rods. 4.24 Forged pistons with rings. Hardly ran. $1000
7. Nice 1UB CJ Crank - All checked out and fresh .010/.010 $450
Blocks/Engines
1. C5AE-A. Center oiler. Standard bore. 1 sleeve. No Welds or Damage. 4G9. $2500
2. 8J15 CJ block. Will need sleeves. $500.
3. Standard bore 427 marine block in great condition. Solid lifter. $2500.
4. 1964 center oiler. .30 over. No repairs. Studed Mains. $2500.
5. 8J4 CJ Block. .030 - Nice condition $1800
5. 428 Engine Complete .030 over A-Scratch Passenger Block
Edelbrock Aluminum Heads and Victor Jr Intake – H beam Rods with TRW Pop ups – Brand New Scat crank in the box – All roller valve train – New bearings in boxes –
Cometic Head Gaskets – New Canton Pan – Mallory Distributor – Everything except a carb – Disassembled for inspection - $6500
7. Complete 427 Tunnelport Engine .030 Side Oiler Short Block – Decent bare Heads & 2x4 Intake –BU/BT Carbs – Roller Rockers – Deep 427 Ford Racing Pan - $ Call Me – Could go a few different ways with this.
Transmissions: Toploaders -
1. RUG AU-1. 1970-71 Torino 429 close ratio. Big in big out. Rebuilt. $1250.
2. Freshly Rebuilt -Short tail housing top loader for small block. C4ZR-A tail housing. $1000.
3. Freshly Rebuilt - Short tail housing top loader for big block/small input. C4DR-A tail housing. $1000.
4. Freshly Rebuilt - Short tail housing top loader for small block. 25 spline output. C4ZR-A tail housing. $900.
5. Freshly Rebuilt – RUG AZ 1970 Boss 429/428 CJ top loader transmission. Rebuilt. C8AR-D Main case. C70r-A tail housing. $2250.
6. HEH D long top loader for 1964 galaxie. Close ratio. Excellent condition. $1000.
7. Freshly Rebuilt - Short tail housing top loader for small block. 28 spline output. DOZR-A tail housing. Rebuilt. $1000.
8. Freshly Rebuilt – RUG AE2 1969 Boss 429/428 CJ top loader. $2250.
9. Freshly Rebuilt - Short tail housing top loader. Small input for big block. CZOR-A tail housing. $1350.
Misc:
1.   NEW - Holman Moody Webber Intake with Fuel Injection set up for an FE – Cost $4900 Sell for $3500
2.   Standard Bore 427 Pistons on CJ Rods - $350
3.   Long Nose FE Starter $50
4.   Very Nice Pair of 64 2 door Hardtop Galaxie doors. - $400/pair
5.   64 Galaxie Dash - $75
6.   64 Galaxie Fenders – One Really Nice Pair -$225 for both
7. 1 Left Front with a little rust behind the headlights - $ 50
8.   64 Galaxie inner fenders – nice shape - $50 each or $75 for both
9.   64 Galaxie hood – Nice Shape - $200
10.   64 Galaxie Deck Lid – Little rust in the back lip but not bad - $150
11.   64 Galaxie Air Cleaner – Nice Blue unit -$50
12.   64 Galaxie Trim and interior Pieces – Call me
13.   NOS 67 Galaxie Rear Bumper – It wasn’t taken care off and its starting to peal in certain spots - $250
14.   FE Expansion tank – Painted Black $50
15.   64 Galaxie and Comet Bumpers – Cores and Driver Quality - $Call Me.
I am trying to raise cash to fund a move back to the west coast. Shoot me an offer on something.
Jack
jacksfordparts at geemail
540 66for for four one ate
