Author Topic: Flywheel / Clutch problem.  (Read 3207 times)
bsprowl
    • Ford FE Information
« on: July 24, 2017, 06:09:16 PM »
In 2009 I rebuilt the 428 engine in my '66 Galaxie. I replaced the stock flywheel with a 390/427 Fidanza flywheel that was balanced to work with my 428.
I assembled the engine and added the flywheel, clutch disk, pressure place, and bell housing and installed the engine.  I started it several times but only got about 200 miles on it when the flywheel ring gear lost several teeth.  I stored the car.
Friday, I start to fix this problem.  Removed the shifter, slid the transmission back out of the way, unbolted the pressure plate and it wouldn't come out.  On Sunday night I removed the bracket for the throw out bearing fork and I was able to pry the pressure plate and clutch disc out of the bell housing.
Measured the clutch disc and pressure plate thickness and they were similar to another set I had.  Measured the flywheel and it's about 0.050 inch thicker that the old stock cast iron one and it's also about 10 pound heavier.
Anybody else have a problem like this?
I guess I going to have the flywheel surfaced to remove at least 0.060 or maybe even 0.125 of an inch.
Any other suggestions for a solution?
(This is also posted on the Fordfe.com forum.)
bsprowl
Re: Flywheel / Clutch problem.
« Reply #1 on: July 25, 2017, 09:41:45 PM »
I carefully measured the OEM Ford and Fidanza flywheels and found many differences.
The Ford Hub is recessed 0.037"; the Fidanza hub is raised 0.045".
The thickness of the Ford Flywheel is 0.832" and the Fidanza is 0.993" thick.
The ring gear back is 0.20" from the back of the flywheel on the OEM part and 0.118 from the back on the Fidanza.
The block plate is 0.085" thick.
Therefore the face of the Fidanza flywheel is 0.245" (0.200 plus .045) further back than the face of the OEM flywheel.
This also throws off the tooth contact by 0.164" (hub off by 0.045 plus 0.037 and ring gear off by 0.082).
I need to have the engine side of the hub faced to fix the tooth contact. (I'd have to use three block plates to restore proper tooth contact without the machining.)
