Author Topic: cj head info  (Read 3698 times)
cj head info
« on: July 12, 2017, 04:43:22 PM »
i have a few questions about these heads,like does the date code effect the value,if so,what is the better dates and when were the last ones dated and last but not least,what is a good set,ready to run,worth?.my set is dated late feb 69.
preaction
Re: cj head info
« Reply #1 on: July 12, 2017, 05:08:14 PM »
That date is among the most common.
Re: cj head info
« Reply #2 on: July 12, 2017, 06:19:44 PM »
I would guess the early heads for a 1968 would be worth a little more, due to being more rare. And Ford made CJ heads for quite a few years after car production ended, those dates probably a little less valuable since they wouldn't be correct for a restoration. However, I would say condition will be important too in figuring value. A set needing lots of work, or that have been milled excessively, or the subject of a bad porting job, will all be worth less regardless of the date codes, especially since CJ heads aren't extremely valuable, so quality of the work will matter too.
Re: cj head info
« Reply #3 on: July 12, 2017, 06:28:45 PM »
i dont want to over charge and i dont want to just give them away either,but what is a good set with only 2000 miles on them since freshened up for a new engine,never milled,no issues,ready to bolt on and run,average price
Re: cj head info
« Reply #4 on: July 12, 2017, 08:24:22 PM »
Numbers matching, fresh, not run, not milled $1000.00-1200.00 to the person who needs them.  If they have to be taken apart to verify work done, the price will come down some as in your 2000 miles usage.  Joe-JDC
