FE Technical Forum
Modifying Water Pump Adapter, Bad Idea?
Topic: Modifying Water Pump Adapter, Bad Idea? (Read 3997 times)
June 26, 2017, 08:31:48 AM »
I'm getting all the parts/pieces in a pile so I can do this water pump change out and electric fan setup. I realized this weekend that I'm going to have nowhere for the heater core supply fitting once I put the CVR pump on. I thought about drilling and tapping the passenger side adapter for the heater core barb fitting. Bad idea?
sixty9cobra
Sr. Member
Re: Modifying Water Pump Adapter, Bad Idea?
Reply #1 on:
June 26, 2017, 02:29:49 PM »
I had the same thought. Jay said to drill and tap the adapter and add a fitting.
Reply #2 on:
June 26, 2017, 04:00:47 PM »
It seems like a simple deal......but then i started having this fear of starving that side of the engine or something. The neighbor is a machinist, I'm going to hand it to him tonight and tell him to go for it.
Administrator
Reply #3 on:
June 27, 2017, 08:13:30 AM »
I think you'll be fine doing that, you are basically just duplicating the factory water routing. No problem, in my opinion. Can't say I've ever tried it, though...
FE Technical Forum
