Author Topic: 390/410 piston ID?  (Read 6221 times)
390/410 piston ID?
« on: June 05, 2012, 08:05:53 PM »
Anyone know what piston a P-1513 is? Looks like stock replacement. 4 reliefs with center dish.
I am guessing truck or 410, sitting over .100 in the hole with a 390 crank
Clearly stamped on piston top, along with a logo sort of like a crown on its side
Thanks in advance
Re: 390/410 piston ID?
« Reply #1 on: June 07, 2012, 06:15:25 AM »
Looks like standard builder pistons, cast, 1.66 CH.
Listing says 360/390/410, if you don't care about quench or compression they fit anything :)
On the fence between adding a 428 crank or buying a cheap set of hypers to get compression and quench back.
We'll see how it unfolds, I am finding myself to be pretty tight on my cash with this iron headed 390.
« Reply #2 on: June 07, 2012, 07:55:00 AM »
Thanks for the update, Ross, it's been quite a while since I've looked at pistons like that...
« Reply #3 on: June 07, 2012, 08:30:10 PM »
Same here, 20 some odd years to be exact for me !
I think the plan is going to be, port the heads and get a good set of tight quench modern slugs in there.
The combination of going from 8:1 to 9.5:1, adding 40-50 cfm of flow, and the RPM should wake it up plenty for the pickup.
It ran good before, but now I know how it's set up, so I have to do something.
