Author Topic: I need help with exh. valve size  (Read 3503 times)
chris_r
« on: June 22, 2017, 07:45:22 PM »
Can i run 1.65 exh. valve in g heads on 4.050 bore?  thanks for the help
Re: I need help with exh. valve size
« Reply #1 on: June 23, 2017, 08:01:12 AM »
I would think so, assuming you aren't running a ton of lift.  Lots of 445s out there with CJ valves.  I run a 1.67 in a D2TE-AA head without any issue.
Years ago I played around on the bench with a C8AE head with a 1.67 and it didn't hit a standard bore on the exhaust side until the valve was well below the guide (no spring of course).  I would expect yours to be the same.  Be sure to check that and radial clearance on the pistons though, some 390 pistons have pretty small eyebrows
CaptCobrajet
« Reply #2 on: June 23, 2017, 06:41:09 PM »
4.050 and 1.650 no problem.  1.600 and 4.000 okay.
Blair Patrick
