Author Topic: Front suspension conversion on 67 Fairlane.  (Read 15673 times)
MeanMofakee
« on: June 22, 2017, 02:01:29 PM »
I want to install a double A-arm coilover with r&p steering on a 67 Fairlane car that is just beginning the build process. Main reason is to eliminate the shock towers and provide some better handling (hopefully) and braking. It seems to me that a lot but not all members here are purists of some sort and may not subscribe to my idea. That's fine and I will consider everybody's input equally. The research that I've been able to come up with is that all of the manufactured units of this type will lower ride height somewhat, the manufacturers won't or can't tell you exactly how much. They offer different spindle options from std. to 2" drop. Some of them also state lower engine location to help with COG as well. My biggest concerns are first and foremost, ground clearance, both oil pan and header. With the need to use a rear sump pan with significantly increased capacity along with limited choice for headers with max clearance, I'm starting to have concerns with a car that sits to low in the front, too high in the rear and just doesn't work. Secondly, will a car with that style front and leafs out back be able to be set up for respectable launches when participating in an occasional grudge/street race. I know there are a lot of other things that go into the equation, but starting with the basics. Don't want to build a race car with some street manners, want a street car that thinks it's a race car. Like a lot of things, I get thinking in one direction and end up turning the other, or worse case just plow ahead and regret it! Thanks for any input that you guys can add to help me with this. What are my options?
« Last Edit: June 26, 2017, 01:10:08 PM by MeanMofakee »
MeanMofakee
Re: Front suspention conversion on 67 Fairlane.
« Reply #1 on: June 22, 2017, 03:11:20 PM »
I guess I should have added, what brands of suspensions did any of you use and was there any issues that you encountered that relate to my concerns from first post.
« Reply #2 on: June 22, 2017, 05:08:28 PM »
Honestly, I think rack and pinion turns into a major pain in the butt. If you're actually going to road race, that's a different story, but for street stuff it's probably wasted effort. Got a '68 Cougar, it has global west control arms, the higher spring rate springs, and a flaming river box. It does everything it needs to, has that pro-touring look too. Then you can at least buy bolt-on parts for it.
My uncle did a '64 Fairlane drag car about 8 years ago and he had to do a rack and pinion front end because the front end sheetmetal was in terrible shape. He made custom headers, custom oil pan, had to redo the steering column. It was a good chunk of work. When all was done, he was still unhappy because the springs were short and didn't allow for great weight transfer.
I've become a big advocate of purpose building cars. Try to get a car that does too many things, and it does nothing well.
« Reply #3 on: June 22, 2017, 09:25:38 PM »
I don't have any direct experience with a Fairlane, but I'll tell you about the other front suspension swaps I've done, one on my Galaxie and one in my Shelby clone.  On the Galaxie I used an Art Morrison weld-in front clip and a Mustang II style front suspension (with tubular control arms and coil overs, not stock Mustang II parts).  I bought Wilwood front disc brakes to match this setup.  That kit used a front steer rack, and required a rear sump oil pan.  That one worked out very well, and the car rides, steers, and handles MUCH better than stock with that setup.
On my Shelby clone I used a Fatman Fabrications front strut kit.  This kit uses late model Mustang spindles, rotors and brake calipers, and an Escort rack and pinion.  This setup is a rear steer rack, so you can still use a front sump pan.  There is a chassis plate that bolts into the the stock lower control arm mounts, so it looked like it would be fairly easy to install.  However, the quality of the kit was poor, and one thing they didn't tell you about was that the kit reduced the front track width by 4"!  I ended up extending the lower control arms that came with the kit to make up the difference in track width.  Calls to the manufacturer were not helpful during the installation.  But, I was able to modify the kit enough to move the front struts outboard and eliminate the shock towers. And, now that it is installed, it drives and handles pretty well.  I wouldn't say its a lot better than the stock Mustang setup, but it is certainly lighter and steering with the rack is an improvement over the factory steering box, in my opinion, although the turning radius has increased somewhat.
If it was me, I'd be looking at the Art Morrison stuff...
MeanMofakee
« Reply #4 on: June 23, 2017, 10:20:52 AM »
Well so far it looks like 1 thumbs down, 1 thumbs up. Just about the ratio I was expecting to see. LOL The fabrication/welding part of doing something like this is not a concern as that's what I've done for a living most of my life, just not hot rod stuff. The issue is the knowledge that only comes from the experience of building a few cars and learning what doesn't work, what works, and what works better! Not afraid to start on a project like this, and it's not really the cost of doing it right (most of this stuff is too expensive to do 2-3 times over) it's the time factor. It's kind of on my bucket list to build a hot rod while I'm still somewhat able, just not to sure how long a guy has. Not worried about tippin over, but I've got some other things I would like to do also. Would love to get a car done to enjoy and have something to leave the grandson.
scott foxwell
« Reply #5 on: June 23, 2017, 11:34:04 AM »
If you do a rack conversion it may cause more header issues than staying with a box. I'm going to do a strut conversion on my 67 Fairlane and keep the steering box. A rack conversion, from what I've read, will give you more header headaches, at least with a front steer. With the strut conversion, you lose the upper control arm and can notch the shock towers. There are very few "Mustang II" suspension conversions that interest me. If I was going to so a SLA suspension I'd be looking at something that was designed from scratch. Most of what you're going to find are systems that are for Mustangs and will need some modification or adaptation. There are a few systems offered for Fairlanes, but you have to search for them. Google is your friend. I've spent hours and hours on Google and probably have a hundred pictures on this very subject.
As far as rear leafs, Calvert is the answer and there are some VERY fast, hard launching cars running leafs and Calverts. That is not an issue.
« Last Edit: June 23, 2017, 11:35:55 AM by scott foxwell »
wowens
« Reply #6 on: June 24, 2017, 11:31:49 AM »
I used Rod & Custom Motorsports on my 67 Mustang, Kit for Fairlane ava & I will use it if I ever find a Fairlane. Headers were custom built by me, modified steering column, custom rear sump pan, external oil pump. Very positive steering feel, apx 4" up travel, install position critical, width stayed same. Overall, I like it. Went 10.31 with wheels up 3 or 4", ladder bars, drove to track, put on slicks, lots of fun. Rich guy at track had more $ than sense, sold it. Want a 66 Fairlane.
Woody
« Reply #7 on: June 26, 2017, 10:39:00 AM »
I haven't done it - considered it - and I'm with Jay, I'd look at one of the "real" chassis builders for a clip.  I worry that the glom on units using welded crossmembers put a different set of stresses on the front inner fenders that the original design.  Not a problem if the car is 10 point caged with runners out into the engine compartment over the upper strut/shock mounts.  But if you are going to bang on it any, I would consider a clip and full connectors in the floor to stiffen the chassis front to rear.  That way you have your ride height and all the technical stuff like anti-dive and such are done as a unit on a jig.  Also nothing wrong with a strut type setup, maybe something like the Total Control deal that uses some late model parts.  You should opt for tunable shock or strut because weight and chassis reaction are not going to be "off the shelf".
As noted, it may cost you as much for headers and oil pan work as the chassis mods.  Lots of people don't seem to think about that, "the kit is only $1995!"  Then they get on their favorite web list and whine that nothing fits but the bare block.  This is hot rodding people!  You'll spend much time with dial indicators fussing over  .001 only to follow up with a 2 lb hammer, 1/2 drill and cutting torch.
I would personally like to mod the Falcon (same as your Fairlane) to take the motor from the dragster so I could play door car guy sometimes, but that big long oil pan pretty well shoots that deal I think.  I'd have to use a subframe kit of some sort because the rack would have to be forward of the engine.
MeanMofakee
« Reply #8 on: June 26, 2017, 01:08:15 PM »
Thanks for all the great input guy's! This is going to turn into a bigger deal than what I was planning. That's all good, like I said before, I want to get this right the first time and not have any regrets with the direction I decide to go. You're opinions coupled with the real world results are most beneficial to me. Anybody have anything to add I'm all ears. Maybe some photos also if that is possible!
Re: Front suspension conversion on 67 Fairlane.
« Reply #9 on: June 27, 2017, 08:47:25 AM »
Most important is that you go at it with the right attitude - which it sounds like you have, want it done well and right.  And, that it's for your satisfaction and not others.  Enjoy the process!  My dragster project took a year from roller to racer, lots of false starts, "how's that gonna work", how's that going to fit, what to do about parts that flat don't exist.  Lots of fab work and just sitting by the car thinking.  Wife is like "tell me again why you're doing this"  "Because it's a challenge and it's fun."  I still kid my footbrake friends that I intend to bolt some door handles on it by the cage.
Also, I have the second "secret" desire to go all out on the Falcon - struts, tubs, 31x14.5 tires, narrow rear, punched 460 or large 351C with a tunnel ram, all 4 doors.  :)
« Last Edit: June 27, 2017, 08:50:10 AM by Falcon67 »
preaction
« Reply #10 on: June 27, 2017, 01:21:57 PM »
Are the Art Morrison front clips ford specific ?
jimeast
« Reply #11 on: June 28, 2017, 05:41:56 AM »
For performance suspension, the coil-over suspensions that use the stock towers by Street or Track and Mike Maier are hard to beat and great on the track and the street.  If I was going to cut out the front clip and put a different type of suspension in, I'd use Griggs if they are still around, but it's a cubic dollar solution that might not be any better than the above listed.  One thing about the Mustang II type suspensions is they provide a nice combination of upgrades (R&P, Coil over and disc brakes) for the overall cost, but they do not handle better than the systems mentioned above that use a stock tower.
As far as shock tower removal, I like the shock tower mods that duplicate or emulate the Boss 429 towers.  http://www.bosskraft.com/boss-429-powered-67.html.  If you have not seen this shock tower, it might offer you a few ideas for your project.
As far as R&P steering, you get what you pay for and Total Control Products makes a very nice R&P, but don't underestimate the capability of the stock steering when it's dialed in.
Sounds like a fun project,  I went back & forth on my goals quite a bit and have decided to start with a vintage setup from Opentracker and Street or Track and see how big the difference is over the 50 yr old tired suspension and then upgrade to a SoT coil over if I think something is lacking
« Last Edit: June 28, 2017, 06:50:50 AM by jimeast »
« Reply #12 on: June 28, 2017, 07:58:57 AM »
No, they are universal.
« Reply #13 on: June 28, 2017, 09:16:06 AM »
As above - BUT, these chassis people have done a lot over the years and can very likely tailor the clip to your exact needs.
I like the Boss towers, that's a more cost effective solution to what I'd like to do.  Dynacorn shows them in their catalog, about $300 a pop.  Part 3631HA (RH) & HB (LH)
http://dynacorndepot.com/shock-towernotched-kit-rh-1967-68-3631ha-mustang-67-68
I'd also add that for handling with the stock type suspension, go get the Boss 302 Chassis Modification book before you go spend a bunch on new fangled suspension parts.  ;)
http://www.cjponyparts.com/book-boss-302-chassis-modification/p/BKBCM/
Between that and parts from people like Global West, you can make a Mustang, Falcon, Fairlane handle like a Trams Am car.
« Last Edit: June 28, 2017, 09:20:45 AM by Falcon67 »
scott foxwell
« Reply #14 on: June 28, 2017, 10:30:00 AM »
Too bad they don't have that  set up for a Fairlane.
