Author Topic: Spark plug wire kits recomendation.  (Read 4071 times)
james
« on: June 19, 2017, 06:22:25 PM »
I have been getting various opinion on this issue. I have a 427fe stroked to 482. This is one set of wires that was recommended. Taylor 409 Pro Race Spiro-Wound 10.4mm Spark Plug Wires 79665, 10.44mm.
Then someone told me about Taylor 409 pro race universal spark plug wire set #79691 10.44mm. What say you guys? Any other recommedations and price is not a main concern. Thank You!
Re: Spark plug wire kits recomendation.
« Reply #1 on: June 19, 2017, 07:22:55 PM »
I use MSD stuff.  The 10.5mm on most racy builds, the less expensive Streetfire ones where we need them to work with factory valve coves and wire looms.
james
« Reply #2 on: June 19, 2017, 07:36:22 PM »
Thank you Barry. I bought your stroker kit for the motor. Can you please provide me with some part numbers? Thanks again.
« Reply #3 on: June 19, 2017, 08:37:09 PM »
Going by memory (at home right now) the MSD race set is 31183 - black with multi-angle plug ends and both distributor ends.
JamesonRacing
« Reply #4 on: June 20, 2017, 10:29:40 AM »
I've had good luck on my street stuff using the Ford Racing M-12259-M302 cut-to-length black wires, then using MSD boot kit for the distributor side to fit my OEM plug style distributor cap.  Gives a nice thick wire with each cylinder labeled along the wire.  The pre-made stuff can make the connections but they usually don't dress as nice as when you cut each one to the exact length you want.
« Reply #5 on: June 20, 2017, 10:46:08 AM »
Think I sued Taylor 8mm universal on the dragster, would have to go look at the invoice.  I know I'm using their wire management parts.  Picked by price and color blue.  Normally over the years I have run 8mm yellow Accel wires and never had any problems.  The primary color scheme on the dragster is purple and blue, so yellow would clash.   8)
