Author Topic: Black Eagle motor mounts  (Read 5342 times)
Katz427
« on: May 20, 2017, 07:45:59 PM »
Has anyone used the Black Eagle racing motor mounts for Fe in a fairlane or comet that are on eBay?
fastback 427
Re: Black Eagle motor mounts
« Reply #1 on: May 20, 2017, 09:26:19 PM »
Yup. Welded up the first set made.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
Katz427
« Reply #2 on: May 21, 2017, 04:46:06 PM »
Jamie, question on height. Are they same as stock mount height?
fastback 427
« Reply #3 on: May 21, 2017, 05:46:13 PM »
Yes. Motor sits where it should from factory. The guy that sells them is a dink though. Way over priced.
Also on edit they are harsh on the vibration .
Jaime
top end toploader
Katz427
« Reply #4 on: May 21, 2017, 08:42:10 PM »
Well that is pretty good then. May be a bit pricey but near everything is. I do not have a shop handy these days so  I do what I can. I would like to install my 427 in the 67 Ranchero. It is a 5.0 right now. As you know room is at a premium under hood. I might do a little work on the shock towers but  those mounts free up a little room around the cross member.
fastback 427
« Reply #5 on: May 21, 2017, 08:57:00 PM »
If i had more time id send you a set free.99. Still have the program to laser them out.
Jaime
top end toploader
