Author Topic: Mahle 1mm 1mm 2mm ring package  (Read 6191 times)
MeanMofakee
« on: May 13, 2017, 11:05:31 AM »
Try this once more. Posted in the wrong forum before. Found out the pistons and rings that are in the stroker kit I bought has the Mahle 1mm 1mm 2mm ring package. Any opinions, good bad or indifferent!
Re: Mahle 1mm 1mm 2mm ring package
« Reply #1 on: May 13, 2017, 11:08:21 AM »
I've never run those, but I've run the 0.043/0.043/3mm ring package with good results.  First two rings are almost the same (1mm=0.040").  No reason those won't work for you...
« Reply #2 on: May 13, 2017, 11:10:26 AM »
Many new cars run those same rings for less drag, better sealing and improved mileage (less drag).  Pro Stock engine also run thin rings...likely even thinner!
« Reply #3 on: May 13, 2017, 11:50:36 AM »
Good rings.
Most of my pistons are either 1/1/2 or 1.5/1.5/3.  No problemo.
« Reply #4 on: May 13, 2017, 01:22:11 PM »
I'm no expert, but with that thin a ring, I'd think bore and taper must be pretty tightly controlled?
« Reply #5 on: May 13, 2017, 01:34:50 PM »
Best production ring package I have used to date.  Run them in everything I can.  Very low friction and seal up instantly.
FirstEliminator
« Reply #6 on: May 13, 2017, 02:15:22 PM »
   That is a wonderful thing to hear.
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
MeanMofakee
« Reply #7 on: May 13, 2017, 03:01:55 PM »
That's good news guys, thanks
« Reply #8 on: May 13, 2017, 03:50:25 PM »
... I'd think bore and taper must be pretty tightly controlled?
This portion of your statement should always be a "given fact".
chris_r
« Reply #9 on: May 19, 2017, 08:40:21 PM »
+2 Barry    I have a lot of small bore fe's with 1,1,2 ring package.  Work great i also run them in everything i can.
« Reply #10 on: May 20, 2017, 10:09:11 AM »
Unfortunately, that's not always the case, so you'd better be sure about your machinist.
