Author Topic: lower hose to Meziere pump questions  (Read 7716 times)
« on: May 30, 2012, 01:17:30 PM »
what are you guy's using for a lower hose ... Mezerie biggest adapter is 1 inch and 3/4 my edelbrock is 2.12 ..... wanting to order a Mezerie WP170BHD 42 gpm pump
Re: lower hose to Meziere pump questions
« Reply #1 on: May 30, 2012, 03:46:26 PM »
I haven't come to the hose conundrum yet, but I've often gone to the local NAPA, selected a couple of suspicious looking water pump hoses, and then pieced them together with steel exhaust tubing and hose clamps to get the size and shape I need.  If you don't want to do that, I'd get in touch with Barry R, because he uses those Meziere pumps all the time and probably knows the best way to git 'r dun...
« Reply #2 on: May 31, 2012, 08:55:33 PM »
I kinda do the same thing - grab about six hoses and try them....
If I remember I'll scoot under my car and try to read the hose p/n....
« Reply #3 on: May 31, 2012, 09:31:45 PM »
somehow I remembered the hose was tight when first installed in 1996 , how I remembered is I'll never know cause I can't even remember what I ate last night ... but I called crites wich is where I got the original hose from and they don't sell them anymore but she gave me the Daaco number , when I called the local parts store he looked the number up and it came back 1 .75 both ends and had one in stock so I ordered ikt and waiting for the new pump .... if the inlet is anywhere close to the Ebrock it should work ... thanks a bunch
« Reply #4 on: May 31, 2012, 09:54:57 PM »
One of my better auto parts stores actually had a book with pictures and we ordered a molded hose that was 1 3/4 at both ends. Luckely I'm a compulsive saver and still had the receipt filled. It was a Gates #20957. Not a perfect fit but it's worked fine for 6 years. Inlet on pump is a slightly different angle, need to give the hose a bit of a twist. Mine is on a Mustang. Try link to Rock Auto http://www.rockauto.com/catalog/moreinfo.php?pk=2485
« Last Edit: May 31, 2012, 09:59:12 PM by thatdarncat »
afret
« Reply #5 on: May 31, 2012, 10:34:20 PM »
Used a Gates 22143 for a CSR pump on a Mustang.  I think the outlet location on the CSR is pretty similar to Meziere.  The hose is longer than needed with an extra bend that has to be cut but fits pretty well.
« Reply #6 on: June 01, 2012, 03:37:22 PM »
thanks guy's .... I wrote the numbers down in case the hose I ordered doesn't fit good
