Author Topic: Building a new 464  (Read 17119 times)
sixty9cobra
Building a new 464
« on: May 01, 2017, 12:10:18 PM »
Hi guys something let go in my current 464. The motor is 8 yrs old many street miles lets say 10k, has 50 track passes plus the usual flogging it on the street. It has Eagle crank, Scat rods, CP pistons 10.5:1 .040 over, Erson rockers, Hooker 1 3/4 headers, 3 inch exhaust, Fidenza 13lb aluminum flywheel. Cam is similar to a comp 294 (custom grind by builder), street master port matched, Holly 850, Msd dist locked timing. Barrys Edelbrock heads pro ported  flows 330 @.600. This combo made 415 rwhp at 5800.
                            What would I need to do to get to 550-600 hp on pump gas? I am assuming it spun a bearing at this point crank is probably toast. Block is good so are the heads. Lets hear opinions.
Re: Building a new 464
« Reply #1 on: May 02, 2017, 09:33:16 AM »
You want 550-600 at the rears? Or at the crank?
Seems like you've got all the right parts, minus the intake. Blair is having me run a port-o-sonic on the 482 motor I'm currently piecing together. It's at his place now, he's putting some kind of voodoo into it. My goal was somewhere in the neighborhood of 600HP here in Colorado at altitude.
bluef100fe
« Reply #2 on: May 12, 2017, 04:17:44 AM »
Without buying everything new, I'd be looking for a portosonic or at least strip dominator intake, both will need port work IMO to get where you are wanting to go, I'd also take a hard look at the oregon cams #175 grind at a minimum for camshaft if staying flat tappet, if your wallet can handle the hit for a roller cam then Blair has a few pretty street friendly roller profiles he likes, I have one and it drives pretty nice in my stroker deal. I'd be looking for bigger headers, more carb if available, if your buying a crank I'd splurge for the forged 4.375 rpm crank also, more cubes the better. There now wasn't that easy for me to spend your money lol. Good luck getting it back together.
Cody Ladowski
1976 F-100 stepside
390 C6 9 inch
1.56 sixty ft.
7.38 @ 91.5
11.79 @ 111.5
« Reply #3 on: May 12, 2017, 06:04:27 PM »
If you keep the Eagle crankshaft, I would suggest getting it magnafluxed to check for cracks.  It seems they have a lot of problems with the FE crank, but not other makes like the SBF, SBC, or BBC.  Joe-JDC
sixty9cobra
« Reply #4 on: May 13, 2017, 09:29:34 AM »
Thanks guys I am not sure what the plan is just yet. May is a bad month for family obligations so I don't have much time to play with the car.
« Reply #5 on: May 13, 2017, 09:46:42 AM »
Not sure what you have for a ring pack - but a bump in compression, and some 1mm or .043 rings, coupled with a matching bump in camshaft would move the power band up and get you a nice piece of what you are looking for without spending a ton of dough.  Does that Streetmaster have the normal plenum mods?  If not you have a nice gain there - if its already done I don't think its holding you back all that much.  Get that package to peak at 6300-6500 instead of 5800 and it will make more steam...
« Reply #6 on: May 13, 2017, 10:08:24 AM »
I agree that a well ported Streetmaster will not hold you back in making 550-600 hp, since Jay made 604.1/632.8 hp with my ported Streetmaster on his dyno engine featured in his Intake Comparo book.   Joe-JDC
« Last Edit: May 13, 2017, 10:50:58 AM by Joe-JDC »
sixty9cobra
« Reply #7 on: May 13, 2017, 11:26:11 AM »
I have Jays and Barrys book I will have to look that over. I would like to keep it on pump gas if possible. I am not opposed to sending the assembly out of town to finally get what I want. My last builder talked me out of a roller cam because I would have to change lifters every 10k miles. He was right the flat tappet is fine the rod bearings are toast now. I think it might be cheaper to change the lifters.
« Reply #8 on: May 13, 2017, 01:36:51 PM »
Check out the dyno chart on page 254 for Streetmaster and stroker 427.  Joe-JDC
sixty9cobra
« Reply #9 on: January 09, 2018, 09:39:03 PM »
Engine is done just got back from the dyno. Did a bunch of pulls each one was better than the last.  623.6HP at 6700 rpm.488 tq
537 tq@5800 when I get the build sheet I will post more details.
« Reply #10 on: January 10, 2018, 05:15:05 PM »
Nice congrats i hope it all works out great for ya
« Reply #11 on: January 10, 2018, 11:47:51 PM »
Great numbers, Harry, ought to make that Mustang scoot right along!
« Reply #12 on: January 11, 2018, 01:54:11 PM »
Very nice, Harry. You even exceeded what you were looking for. Hope you get it together and make it to the FE R&R this year. Any pictures you can post?
sixty9cobra
« Reply #13 on: January 11, 2018, 03:23:56 PM »
just a crappy cell phone vid on Facebook. I doubt im going to the Reunion it hasn't been treating me very good. I will pick it up next week then I can take some pictures.
sixty9cobra
« Reply #14 on: August 31, 2018, 06:08:00 PM »
I finally had some time to look for my cam card.
                           intake         exhaust
duration at .050   266.00 ,     272.00
gross lift              .690,          .700
lobe lift               .3990,        .4050
110.0 centerline
110 lobe separation.
