Author Topic: Criuce-o-matic to a C4  (Read 5494 times)
« on: April 28, 2017, 07:41:22 PM »
Any one that have tried to convert a C-omatic bellhoudin to a C4?
Russ67Scode
Re: Criuce-o-matic to a C4
« Reply #1 on: April 28, 2017, 08:58:06 PM »
Did FORD make a bell housing for a C4 behind a FE ?
« Reply #2 on: April 28, 2017, 08:59:12 PM »
Not that i know about
« Reply #3 on: April 28, 2017, 10:45:43 PM »
You can buy C4 bell for FE
« Reply #4 on: April 29, 2017, 02:47:21 AM »
Yes you can, But why take the easy way out ;D
Royce
« Reply #5 on: April 29, 2017, 08:16:48 AM »
We use cruise-o-matic bell housings to put C-4s behind Y blocks all the time.. Basically it involves opening up the center to accept the C-4 pump then drilling holes so that the pump bolts mate the bell housing and tranny together
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
« Reply #6 on: April 29, 2017, 11:53:30 AM »
The dept on the C-O-M bell is right? figured that would be possible with a litle
lathe and mill job
Royce
« Reply #7 on: April 29, 2017, 01:46:14 PM »
For a Y block the distance is not right.  That is overcome with a spacer and a crank bushing. You would need to measure for the FE, it is probably different
1992 BMW V-12 5.0
« Reply #8 on: April 29, 2017, 03:26:55 PM »
Yes i have asked a friend and he think he has a couple of C4 bells somewhere
so i can compare a C-O-M bell to a C4
You have spaced Betwen the bell and the block?
Royce
« Reply #9 on: April 29, 2017, 05:18:37 PM »
You could space the bell housing but then you would have to space the flexplate.. On a Y block we make an aluminum bushing to go in the pilot bearing hole and accept the converter . Then for a Y block we make a 4 steel spacers that bolts between the flex plate and the converter. It seems a little sketchy but mine has held up to 500 hp on my drag car   One guy accomplished the same thing with an aluminum ring between the flex plate and converter.  When you compare bell housing depths it will guide you on what you need.
1992 BMW V-12 5.0
« Reply #10 on: April 29, 2017, 06:16:37 PM »
Interesting since i have a few  Y-blocks to
